Old October 18, 2008, 07:03 PM
Default final build
Gaming
$1000-1500
Canada
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
Any
no
yes
yes
soon, gotta save up.
this is what I have so far.
CPU: E8400
Mobo: Aus P5Q
GPU: 4870 or 4870X2
PSU: Corsair 750W
Case:silverstone fortress
CPU Heatsink: Zalman
HDD: Seagate barracuda 500GB
Drive: LG DVD Drive
Keyboard: need
Mouse: need
Thermal paste: MX-2
OS: Windows vista home basic 64bit OEM
this is what I've picked so far. not sure of the price so if you guys could help me find the cheapest to pricematch at NCIX.com. as for the gpu, if you guys can build me a PC with a 4870x2 for under 1500 including the OS, I'd appreciated it.
Old October 18, 2008, 07:09 PM
Infiniti's Avatar
What resolution will you be playing at? If its at 1680x1050, then a 4870 will do fine. Then, you can save some cash and go with a P5Q-Pro, so in the future, you can put in a second 4870.
Old October 18, 2008, 07:11 PM
yeah it will with 1680x1050 on a 21.6 inch monitor.
Old October 18, 2008, 07:12 PM
Xilikon's Avatar
I agree with Infiniti and for the cpu heatsink, get a Xigmatek HDT-S1283 instead (cheap, very efficient and quiet).
Xilikon - Team 33
Proud to be [H]ard !
Old October 18, 2008, 07:33 PM
JD JD is offline
I 3rd the Xigmatek heatsink or OCZ Vendetta 2.
If you want to squeeze the HD4870X2 into your budget, get a cheaper case.
I'd definitely suggest the P5Q Pro at least or even the P5Q-E. I don't really like how the P5Q is designed (odd shaped heatsinks, ATX power connector in a totally stupid place).
And for the hard drive, get a Western Digital 640GB. Way faster than that 500GB Seagate.
Old October 18, 2008, 09:59 PM
alright guys. updated rig.
CPU: E8400
Mobo: Asus P5Q Pro
GPU: Visiontek 4870
PSU: Corsair 750W
RAM: G.Skill 1000mhz 2x2GB
Case: Antec three hundred
CPU HS: Coolermaster GeminII S
LG DVD Drive
500GB Seagate
Logitech G15
Razer red anarchy
MX-2 thermal paste
Windows Vista Home premium 64bit
Total: 1,278.86
all good?
Old October 18, 2008, 10:30 PM
misterlarry's Avatar
Looks good to me, although I'm not familiar with the cpu cooler. Don't forget to post a build log, and welcome to HWC! Seemed to have missed welcoming you before.
Asrock Z68 Extreme3 Gen3 - Intel i5 2550K @ 3.4 GHz - Corsair H80 CPU Cooler- 4x4 GB G.Skill Ares DDR3 1600 - EVGA GTX560 Ti
1x120 GB Mushkin Chronos Enhanced SSD - 1x500 GB Seagate Hybrid Momentus - 2x500 GB Seagate Barracuda 7200.11 - Pioneer DVR-212D - Antec P182 - Corsair TX650 - 22" Hanns-G - Windows 7 Pro 64 SP1
The world is your oyster. Shuck away my friend, shuck away!
Old October 19, 2008, 05:18 AM
Mr. Gruntsworthy's Avatar
seriously, you want an OCZ Vendetta II :)
MAIN RIG:
Case: Antec 900
CPU : Intel E8400 45nm Core 2 Duo @ 3GHz 1333MHz FSB
RAM : 4GB DDR2 800MHz (OCZ Platinum)
HDD : Main: 120GB SSD (OCZ) Media: 500GB (WD) Storage: 1TB (WD)
GFX : HD4850 (512MB)
PSU : 610W PC Power Silencer
MoBo: Asus P5Q SE
View : Acer H213H 21.5" @ 1920 x 1080
Oshawa Deathmatch Community -- An open group for Durham/Toronto Airsoft, Paintball, and Nerf players. Come join!
My Game Dev website: http://mikeseguin.webs.com/
Old October 19, 2008, 05:41 AM
Xilikon's Avatar
Or Xigmatek HDT-S1283 or even Kingwin RVT-12025. They all have the same design and same performance ;) Coolermaster heatsinks is so-so.
Xilikon - Team 33
