Old October 17, 2008, 12:11 PM
S_G's Avatar
S_G S_G is offline
620HX is good, but even the 520HX is more than enough for you. 620 does give you breathing room to add more things in later though.
As for the CrossFire/SLI thing:
CrossFire or CrossFireX = ATI cards
SLI = NVIDIA cards
Any P35/P45/X38/X48/5400 chipset board will do CrossFire if it has two PCI-Express x16 (PCIe-x16) slots. Note that this is not the same as PCI or PCI-X, and PCI-E comes in many variants: x32, x16, x8, x4, x2, x1. The larger the number, the longer the slot and the greater its bandwidth. You can also fit a smaller card into a larger one (e.g. x1 in x16).
For either CrossFire or SLI, you need two or more PCIe x16 slots. In the case of the P35 and P45, the x16 slots actually run at x8, but are sized x16. This is still fine for running two cards.
While CrossFire runs on any of those boards, SLI has more strict requirements. For SLI, the board must be "certified" for it. Basically, that means it needs an NVIDIA chip -- any NVIDIA board with two PCIe x16 slots should work. The upcoming X58 will have certification on a board-by-board basis, not just for NVIDIA boards.
HTPC: MSI Z77A-G43 + i5-3570k@4.6 + 16GB DDR3-1600 + GTX 580 + X-Fi Platinum on water
Work: 13" MacBook Pro Retina 512GB
Old Workstation: X7DWA-N : 2x Xeon E5330 Quads @ 3GHz + 24GB FB-DIMM DDR2-800 on water
1x 8800 Ultra --> Sony GDM-FW900 + LVM-37w3se // HT Omega Striker ~ (optical) Pioneer SE-DIR800C ~+ SE-DHP800 / HD 280 Pro
Old October 18, 2008, 06:48 AM
Leclerc's Avatar
Originally Posted by timiny_cricket View Post
Hmm, I don't think I fully understand the PCI business with the video card. So you're saying that it only takes one PCI-E slot, but it takes another regular PCI slot, which doesn't really matter because the audio and network is built in to the mobo and I have no need for another PCI card? And this would not prevent one from being able to have multiple 9800GTX+'s in SLI?
It means that the card with his cooler is so thick that it will overlap the nearest slots. But any high end card have this configuration.
If you would like to keep the multiple video card option you will need to go with ati card. Something like a hd4850 will be more than enough and in a year or two you will be able to get a second 4850 to get up to date at a cheap price. The 9800gtx+ is a great card but you will be stucked with it and need to change it when you will need to upgrade.
Over this, the 620w is a great psu and will give you some room for upgrade, even for a crossfire configuration if you don't get high overclock.
AthlonX2 4600+ @ 3.0Ghz (tweaked by Ebdoradz) | Gigabyte MA790X-DS4 | 2x1GB Mushkin HP PC2-6400 @ 860Mhz | Silverstone Strider 500W PSU | Palit Radeon HD 3850 @ 720Mhz/1.76Ghz on 22" Acer X223w monitor | Thermaltake SopranoRS 101 | 1 x Seagate 250GB
Old October 18, 2008, 12:20 PM
Lithotech's Avatar
For a 19" monitor, just go with a single decent vid card and don't worry about pairing it up. By the time you get around to it a single new card will beat a pair of 9800GTXs anyway.
I run an 8800GT as well as a 9800GTX+ on a 19" and I get rediculous high framerates with all the details maxed, 16X AF 8X AA. The only game that has been pushing it is Zombie Panic Source, where it drops to 40-50FPS occasionally. Otherwise, 100-250FPS.
I am leary of NV products these days, but the 9800GTX+ is still a nice card for the money. Otherwise, I can't wait to try ATI again for my next vid card purchase. The 4870 runs hot but is an excellent price for performance. I've always prefered NV for the lifetime warrantys.
The 620W is a better unit, better now than later since the price diff is small compared to the overall system cost. That said, the 500W is more than enough.
eVGA 680i SLI (A1) P31
Intel Q6700 Kentsfield | Scythe Ninja-B | Antec Tri-Cool 80cfm
4GB (4x1024MB) Corsair Dominator 8500
boot: 4x WD Caviar SE16 250gb SATA2 Raid-0
backup: Seagate 500gb 32mb SATA2
eye: eVGA 9800GTX+ SC 512mb 770/2.25ghz
candy: Samsung 940B-HAS | X-Fi XMusic | Pioneer DVR-212D SATA
juice: PC Power & Cooling 750Quad | Cooler Master HAF932
steering: Logitech G15 & G5 | E3D Pro/Momo Wheel | X-530's
