<~----> Contemplating a wood PC - Page 3 - Hardware Canucks
  #21 (permalink)
Old October 17, 2008, 12:07 PM
Dead Things's Avatar
I've had some bad luck in the past with things exploding. What safety measures will you take in case your PSU or PWMs decide to spontaneously erupt into a ball of flame? With a metal case, the damage is relatively contained and most of your other components are salvageable. In a wood case, I could imagine every last component in there going down with the ship if you don't plan for that contingency carefully.
  #22 (permalink)
Old October 17, 2008, 12:10 PM
cwestwell's Avatar
It would take one hell of a hot long burning flame to set this ablaze if it is properly lacquered....it would certainly char the finish but I think the power would be cut off before any fire was able to consume a case like this....
_______________________________________________
E8600 420x10 |Thermalright 120 Black | Maximus Formula | ATI 4870X2 | 4GB Buffalo FireStiX PC8500 | Corsair HX1000 | Lian Li V2010B | Vista Ultimate 64bit
Q6600 334x9 |Thermaltake Blu Orb | ASUS P5Q-PRO| ATI 2900XT | 6GB Corsair XMS2 PC6400 | Corsair HX520 | Lian Li V600B | Vista Home Premium 64bit
  #23 (permalink)
Old October 18, 2008, 10:16 AM
Lithotech's Avatar
The problem with wood is that it is a heat insulator and is hard to get the heat out of it. The best examples of wood cases I have seen have a lot of fans and usually isolated chambers for the HDs etc. Not a huge problem as long as you are aware and plan for extra cooling and airflow.
The benefits (to me) are excellent sound insulation and elegant appearance. I love anything made of fine wood with any variety of finishes. I am terrible at working with wood, but great with metal. I can appreciate metal finishes too, but it just doesn't have the same craftsmanship and ambience of wood.
Sure, it's been done before, but not often. I assume anyone with a collection of woodworking tools will love an opportunity to use them with such an ambitious goal!
eVGA 680i SLI (A1) P31
Intel Q6700 Kentsfield | Scythe Ninja-B | Antec Tri-Cool 80cfm
4GB (4x1024MB) Corsair Dominator 8500
boot: 4x WD Caviar SE16 250gb SATA2 Raid-0
backup: Seagate 500gb 32mb SATA2
eye: eVGA 9800GTX+ SC 512mb 770/2.25ghz
candy: Samsung 940B-HAS | X-Fi XMusic | Pioneer DVR-212D SATA
juice: PC Power & Cooling 750Quad | Cooler Master HAF932
steering: Logitech G15 & G5 | E3D Pro/Momo Wheel | X-530's
  #24 (permalink)
Old October 19, 2008, 11:49 PM
Hey S_G
You know what would be a cool case, and best yet it hasn't been done yet?
I think a granite or marble case. You could probaly find it for 40 dollars a square foot. Maybe less since there is no installation work.Since most facilities have water jet cutter, you could get them to put fancy cuts in it.
I might do this in the future, but not now. Sure its a heavy material but it is incredibly badass.
Sure it might cost you 400 for the material, but you would have a unique case that's never been done. I think the thermal properties are better too.
  #25 (permalink)
Old October 20, 2008, 07:00 AM
cwestwell's Avatar
Now that would be awesome ...Black Marble case ...ahhhhhhhh
  #26 (permalink)
Old October 20, 2008, 05:26 PM
Lithotech's Avatar
Theft-proof. You'd need a forklift to move it.
  #27 (permalink)
Old October 20, 2008, 05:32 PM
cwestwell's Avatar
yeah it would like need to be a small form factor cube that way you could move it and it would allow you to build it out of 1X1 marble floor tiles...hmmmm we may be on to something here.
  #28 (permalink)
Old October 20, 2008, 07:12 PM
Not a bad idea. it would be quite liftable in that case. But if I was going to build one, I would make it a full case.
if you could get 1 cm granite, I don't think it would be anymore than 50 pounds.
If its 2 cm, it would be crazy heavy.
Toronto Granite Prefabricated Granite Countertops Kitchen Vanit
Not any relation to me, but any of the colors in the first picture would make a kick ass case.
If I was going to build one those, I would use emerald pearl color.
What I would do to simplify the process is gut out a full case for the rails.
Atleast it would be flame proof.
  #29 (permalink)
Old October 20, 2008, 11:54 PM
zzaa604's Avatar
Would love to see how this project turns out in the end. Would definitely be an original idea.
  #30 (permalink)
Old October 21, 2008, 12:15 AM
S_G's Avatar
S_G S_G is offline
Marble, granite... That would be hard as hell to work with.
It's all old! Workstation: X7DWA-N : 2x Xeon E5330 Quads @ 3GHz + 24GB FB-DIMM DDR2-800 on water (Goodbye, Skulltrail.)
Rocketfish LL case painted black // PCP&C Silencer 750W
1x 8800 Ultra --> Sony GDM-FW900 + LVM-37w3se // HT Omega Striker ~ (optical) Pioneer SE-DIR800C ~+ SE-DHP800 / HD 280 Pro (HD380Pro soon)
HTPC: E1200@3.2 + IP35 + 4GB DDR2-800 + HD4850 + Silverstone Kublai KL02
Router (WIP): Intel Atom 230 + Intel PRO/1000 GT + GS108T gigE switch + WRT54GL + a drawer
