<~----> Home Theatre PC build - Page 2 - Hardware Canucks
Old October 15, 2008, 09:04 AM
CMetaphor's Avatar
Quadfather
By "higher" I meant better quality, hehe.
Old October 15, 2008, 01:26 PM
Mr. Gruntsworthy's Avatar
well then, is the 350W psu that comes with the Antec Minuet good for it?
And the Minuet seems small, which is what I need; a small profile housing for a core 2 duo htpc. It shall be sitting underneath my xbox 360 on my electronics shelf (which is actually kind of small).
MAIN RIG:
Case: Antec 900
CPU : Intel E8400 45nm Core 2 Duo @ 3GHz 1333MHz FSB
RAM : 4GB DDR2 800MHz (OCZ Platinum)
HDD : Main: 120GB SSD (OCZ) Media: 500GB (WD) Storage: 1TB (WD)
GFX : HD4850 (512MB)
PSU : 610W PC Power Silencer
MoBo: Asus P5Q SE
View : Acer H213H 21.5" @ 1920 x 1080
Oshawa Deathmatch Community -- An open group for Durham/Toronto Airsoft, Paintball, and Nerf players. Come join!
My Game Dev website: http://mikeseguin.webs.com/
