Old October 12, 2008, 01:15 AM
Default First Build
My budget is $1100. it will be used mostly for gaming. I wanna stick with Nvidia..because I there black and green look(stupid reason I know). This is what I have so far.
Updated
CPU: E8400
Mobo: 750i
GPU: GTX 260 Core 216
RAM: G.Skill PC-8000 1000mhz 2x2GB
PSU: Corsiar 650W
Case: Antec three hundred
OS: Windows Vista Home Premium 64bit
Other: Two green cathodes, two Scythe 120mm fans, OCZ vendetta 1, Thermalright bolt thru kit, HDD, LG DVD writer.
total price, 1064. might go for a gigabyte mobo to get the price below 1000.
Old October 12, 2008, 01:24 AM
as forthe OS, I have a retail copy of windows XP business which IIRC, has an option for 64bit or 32bit right?
now the number one game I wanna play is Crysis. could I play very high at 1680x1050?
Old October 12, 2008, 03:56 AM
Babrbarossa's Avatar
Looks good to me! Although I'd probably buy the PC- 8500FireStix on sale right now at NCIX
Old October 12, 2008, 06:19 AM
Based on Tom's chart, you can expect an average of 23.6 fps at 1680x1050 at Very High without AA. But Crysis is really not an easy game for GPU. Maybe I'd consider buying an EVGA GPU to maybe use the Step-up program if there is a new card that comes out in the next 90 days and that does really well with Crysis
I would sort of suggest you switch to another mobo such as the Asus P5Q-Pro or maybe the Gigabyte P45-DS3L.
Other than that, I guess Barbarossa is right about the RAM. Not too sure if you forgot about it or you already have one, but there is no HDD or DVD burner.
Old October 12, 2008, 06:50 AM
Xilikon's Avatar
You got a retail box ? You should be able to use either 32 bits or 64 bits. However, I assume it's XP Professional (XP Business doesn't exist, or it is Vista ?).
Xilikon - Team 33
Proud to be [H]ard !
Old October 12, 2008, 07:35 AM
Eagle Eye's Avatar
Just out of curiosity has the "video corruption bug" that has plagued the nForce 7xx series been fixed?
I'd hate to see xghostz suffer any issues when gaming or watching movies especially when he's on such a budget.
Old October 12, 2008, 09:52 AM
your right it's professional lol. my mistake.
Old October 12, 2008, 09:54 AM
I see...well I actually set up two builds. one ati the the other nvidia(this one).
CPU:E8400
Mobo:Asus P5Q P45
GPU:Visiontek 4870
PSU: Corsair 650W
RAM: G.skill 2X2GB
it's a little cheaper but preformance wise, which would win? the Nividia or ATi?
also, the prices include the dvd burner, hdd, heatsink, others.
Old October 12, 2008, 09:55 AM
yeah I was going to pick em but the sale ended quickly. any ideas for cheaper 1066 4gb ram?
Old October 12, 2008, 11:13 AM
XP is only 32bit unless you specifically order the 64bit version.
With that said.. XP 32bit will do you fine.
