Old October 24, 2008, 07:12 AM
sswilson's Avatar
Which silverstone are you running, and is there a breakdown of the 12V rails available somewhere?
Could be that you're overloading one particular rail and that swapping around which connectors you use might do the trick.
Old October 24, 2008, 03:55 PM
This is my PSU. SilverStone Technology Co., Ltd - Designing Inspiration
The powering off only started once the second video card got added.
Old October 24, 2008, 04:26 PM
MpG's Avatar
MpG MpG is offline
Try swapping some of the plugs around. No way you're pulling anywhere near 750W, especially with a dual-core proc. When Jonnyguru tested that supply, he found the 5V line going out of spec under medium or high loads, not sure if that would cause this problem. modern GPU's mainly live on 12V power, but they do require 5V power as well.
Old October 24, 2008, 04:33 PM
Absolutely agree.
My dual core overclocked and my 8800GT overclocked doesn't tax my 750w either.
Old October 24, 2008, 04:57 PM
sswilson's Avatar
Unfortunately there's nothing on the site showing which rails the PCIe plugs are connected to, but it might be a good guess that there is one on each rail.
That'd be where I start looking... leave PCIe1 plugged into your first card and try the other two PCIe connectors on your second card to see if one of them has less load on it than the one you are currently using.
Old October 25, 2008, 01:27 PM
I'll try switching some plugs around but there's not too much I can do besides switch the PCI-E 6pins and the one 4 pin. My video cards require 2x6pins and each 2pin set comes from 1 on the PSU. Thanks
Old October 25, 2008, 05:19 PM
Switching didn't yield any results. I also played some COD4 today (probably the most demanding game I have) and it crashed pretty quick. I was pulling over 520W sometimes according to the fan controller. Anyways I'm not sure how accurate it is to begin with. Looks like I'll take up my friend on his offer since I want to keep my modular stuff and this way I wouldn't have to rewire. Thanks for the help everyone.
