You should all do a better job at making sure the new member gets the best support possible, and that includes doing some research before replying - and forget the sticky, I don't need one to tell you this:
the 4870 / 4850 won't fit inside that case. Nor will the 9800 / 9600 series. Nor will the 200 series.
From Silverstone directly:
Due to the center-mounting optical drive design, the space for longer graphics cards are limited to approximately 225mm assuming the optical drive used is 160mm long. The following are the length of the various cards for reference:
AMD Radeon HD 4870/4850 = 235mm
NVIDIA GeForce 9800GT/9600GT/GTO = 230mm
NVIDIA GeForce 9500GT = 175mm
AMD Radeon HD 4670/4650 = 170mm
