Old September 30, 2008, 04:01 PM
Default Advice on Jiff's Rig
Hello,
I was hoping to get a little advice on a new system I'm building.
The PC will be used for World of Warcraft mostly, but I tend to download a lot of torrents and burn CD/DVD's at the same time as playing. I have no intention of overclocking.
Budget is not an issue
Here's what I'm looking at buying: (my questions are below)
Intel Core Duo 2 E8500 64bit Dual Core (2x 3.15Ghz, 1333FSB, 6MB Cache) $218.00
Asus P5Q-E (Intel P45, 1600FSB, Dual Channel, Dual PCI-E 2.0 Crossfire, Core Duo2, Quad Core, ATX) 2 PCI-E x16, 2 PCI-E x1, 2 PCI, 4 DDR2, 1 ATA133,8 SATA2 (RAID), 1 ESATA, Firewire, 8 - USB 2.0, 7.1 Audio, Dual Gigabit Ethernet
$193.00
OCZ OCZ2G8008GK PC6400 800Mhz 8GB Kit (2x4GB, 5-5-5-18, heatspreader, Lifetime) ($35MIR = $160.00) $195.00
----Or
OCZ OCZ2G8004GK PC6400 800Mhz 4GB Kit (2x2GB, 5-5-5-15, heatspreader, Lifetime) ($25MIR = $79.00) $104.00
2x(RAID 0) Seagate 500GB 7200RPM (SATA2 32MB Cache) $81.00
(1x) ATI Radeon HD 3870 512MB GDDR4 PCI-Express Video Card $249.95
OCZ GameXtreme 700w SLI (120mm, 2 PCI-E , PFC,4-12v rails, ATX2.2)($30MIR = $96) $126.00
Coolermaster 690 (Front USB2.0/Firewire/eSATA, 2x120mm, Tool-less, Black, ATX) $86.00
Microsoft Windows Vista Ultimate 64bit OEM (CD & License) $221.00
The questions I have are:
Will I have any issues running 8gb of ram on the P5Q-E?
Is the power supply going to be sufficient? (will only be running one card)
Will the Coolermaster 690 case keep the system cool without having to add an after-market cooling solution?
Thanks in advance!
\Jiff
Old September 30, 2008, 04:16 PM
misterlarry's Avatar
Only one thing caught my attention. You can get a 4870 video card for a little more or a 4850 for about $50 less.
Good luck and welcome to HWC!
Asrock Z68 Extreme3 Gen3 - Intel i5 2550K @ 3.4 GHz - Corsair H80 CPU Cooler- 4x4 GB G.Skill Ares DDR3 1600 - EVGA GTX560 Ti
1x120 GB Mushkin Chronos Enhanced SSD - 1x500 GB Seagate Hybrid Momentus - 2x500 GB Seagate Barracuda 7200.11 - Pioneer DVR-212D - Antec P182 - Corsair TX650 - 22" Hanns-G - Windows 7 Pro 64 SP1
The world is your oyster. Shuck away my friend, shuck away!
Old September 30, 2008, 04:57 PM
bojangles's Avatar
IMHO, get a 1 TB Spinpoint F1 or something because you won't have much gain from onboard RAID. About the 8GB RAM thing: I have no idea if ATI has fixed their bug with their Radeon cards and 8GB of RAM. PSU: Corsair 620HX. Best PSU I've had ever. Your case will be perfect. You can always add more fans if you don't like its cooling.
Old September 30, 2008, 04:58 PM
and be sure to check out Canadian Prices: Search. Compare. Buy. - Canadian Online Shopping Search and Comparison! you can PM alot of those item's @ncix.
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
Old September 30, 2008, 07:39 PM
Kayen's Avatar
Why a 3870?
As above 4850/4870.
Heck ,even a 8/9800GT beats an HD3870 for around $120 less .
Old September 30, 2008, 08:11 PM
"Quote This..."
Get a quad core if you are multitasking like that.
Old September 30, 2008, 08:13 PM
"Quote This..."
Screw that 3870. uh uh no way. 4850 is twice as fast for $50+ less.
Old September 30, 2008, 08:24 PM
quad won't help him.
But why are people so insistent on the 8500 for ?! The 8400 is MUCH better and cheaper
Old September 30, 2008, 09:33 PM
Menello's Avatar
I have to go with what enaberif said on this one as well, go with the 8400 instead. Save a few bucks and easily OC it to 3.15GHz or whatever else you want, really.
And don't get the 3870.
The box:
Mobo: eVGA NF66 nForce 650i Ultra SPP
CPU: Intel Core 2 Quad Q6600 @ 3.03GHz
RAM: 1x2GB
OCZ DDR2-800 PC2-6400
+ 2x2GB Crucial DDR2-800 PC2-6400
= 6GB RAM (finally more than 2GB!)
GPU: XFX GeForce9800GTX+
HDDs: 500 Seagate, 640 GB WD Caviar Black
PSU: CoolerMaster 600W
Old October 1, 2008, 10:17 AM
Wow I really appreciate all the replies, thanks a lot guys.
I'm a little confused with regards to the "8400" though.
I search for 8400 under Video Cards at Hardwarecanucks.pricecanada.com and come up with many results, both 256mb and 512mb. I hate to ask but can someone please tell me which one we are referring to?
Thanks again
