Wow, I smell another nice long build thread! Welcome to HWC, looking forward to watching this thread!
The $900 system is lacking an LCD, quad core, and the PSU comes with the case. The rest of the parts are good choices, low cost good quality. The Sonata III is a fairly quiet case, a little cramped but a good heavy solid box to house anything that will fit. Actually very nice systems for $900 w/ tax included.
Your current running total must be below what you originally figured? Dumping the nV board and DDR3 would take a whack out of the price.
Don't even
think about overclocking a system to make a deadline! Even if you already have a config you know is stable, if it backfires on you, you will loose more time than you could possibly save over a month of rendering. Getting a stable overclock can take a long time, and should be done on a system that is otherwise not in use, and fully ready for a complete and utter crash. You will have plenty of horsepower at stock speeds!! Having said all that, once you reach a stable clock speed, I have found it completely safe. My home server runs an E2180 at 3.2GHz, it's uptime is somwhere around 2 weeks about now, it sleeps most of the time and has been running an online game server when I wake it up -- I don't think it has
ever crashed.
Lian-Li being all aluminum cases, will typically make more noise anyway. Waste of money for a workstation, really.
I feel your attraction to the Cosmos 1000! I've been agonising over the same thing for quite some time now.
I have an Antec P180, and 1) it is too cramped for my current system, 2) it can't handle the heat of the current vid cards, 3) my version sucks for cable management, and 4) I am bored of it. Yeah, it's quiet, but only when the fans are low/med. It suffers from intake air blockage due to the little doors, filters, and FP door. It does help with dust inside the case, but does not eliminate it.
I think the Cosmos 1000 isn't a problem if you are only using one or two hard drives. I need 5-6 drives in the system, and when you fill all the trays in the 1000 there will be problems. The drives are orientated wrong, the first drive will block any air going to the rest of the drives. The fan only cools the top row, there is no airflow at all for the lower row. So with two drive in the top row, leaving out the bay for the middle drive, things won't be too hot at all imho.
Another option for a case is the Enlight SR506 pedestal server case:
Enlight SR-506 5U Pedestal Server Chassis Black ATX CEB EEB 3X5.25 8 Hotswap HDD Bays No PS - DirectCanada NCIX.com - Buy Enlight SR-506 5U Pedestal Server Chassis Black ATX CEB EEB 3X5.25 8 Hotswap HDD Bays No PS - SR506101 In Canada.
Despite it's cheap price, it is by no means a cheapo case. It is built like a tank. It has plenty of room inside, and cools extremely well. I use it for my home server. It'll hold 5 hard drives out of the box (4 in the removable bay, 1 in a 5.25 bay adapter) with an optional second 4 drive bay you can buy separate. I made some changes to it's stock cooling, which will bring it's cost up over $100, but will then run extremely quiet and still have the option to turn on the jets for high level cooling. What I did was pull the huge 120x35mm delta fan out of the rear and put in a Scythe S-flex. I then added 2x zalman 90mm fans in the front, one on each of the front drive bay mounts (ZM-F1's, I put the brackets in storage, I must have 10 of them now lol). Lastly, I added a Sunbeam 4 port Rheobus fan controller to control the two front intake, rear exhaust, and cpu fan. It runs quieter than my P180 when the fans are set half way on the dial.
Here's my post in the pics thread on it:
http://www.hardwarecanucks.com/forum...ight#post84538
The only thing about it is the front bezel is plastic. While not too fragile, I can see it could be broken easy by an errant foot if the case is on the floor. The good thing is, the bezel comes off so easily it is amazing, yet stays on firmly. The door itself also comes off the bezel, and the system doesn't look half bad without the door. I can imagine a lot of these cases in a rack mount would be run without the doors.
For cheap simple reliable and quiet cpu cooling, I still love the Arctic Cooling Freezer Pro. The fan comes off in 2 seconds for cleaning, and has a 6 year warranty. At full speed (~2300 rpm) it is rather loud, but let the mobo control the speed (Asus Q-Fan) or use Speedfan to slow it down just below 2000 rpm and you won't hear it anymore. It performs great at stock speeds under extended loads. It'll falter at high overclocks under load. It can be had for as little as $20.
For another $10, the current champ of cpu cooling around here these days is the OCZ Vendetta 2. There is a review of it here, showing it beat or match temps from heatsinks three times it's price. Very impressive. Similar design to the Freezer, except it's fan is a PITA to remove or install.
Lastly, there is another build thread here some 40 pages long. You may want to sit back with something to sip on and have a long relaxing read. Lots of good info in it that could apply to you. Link:
First actual build, parts figured, couple questions
