Old September 16, 2008, 06:39 AM
Mr. Gruntsworthy's Avatar
Default Antec 900 | E8400 build
I'm building a new machine to upgrade from my current E4600 build.
Here's what the finished new machine will have:
UPDATED Friday, Sept. 26
PSU:
CoolerMaster eXtreme Power Duo 600W PS
Processor:
>>Intel(R) Core(TM)2 Duo CPU E8400 @ 3GHz (2 CPUs) 1333MHz FSB
HSF:
>> OCZ Vendetta II
Memory:
4096MB RAM (DDR2, 800MHz) 2 x 2GB Apacer
Hard Drive:
>>1 x 160GB (SATA); >> 1 x 500GB (SATA3G)
Video Card:
Asus EN9800GT Ultimate 512 DDR3 OC PCIE2
Monitor:
19" flatscreen (i'm not in need of anything too big or fancy)
Sound Card:
>> onboard
Speakers/Headphones:
>> tall and black, worth about $30 CDN
Keyboard:
media keyboard
Mouse:
>> USB Optical
Operating System:
Windows Vista Home Premium 64 bit
Motherboard:
>> Asus P5Q SE LGA775 ATX PCI-E EPU MB
Computer Case:
>> Antec 900
the parts with a '>>' next to them are already in my posession. The rest are yet to be bought, and are basically set in stone unless someone makes a better suggestion.
My budget is around $700 CDN. I prefer Intel to AMD, but that's the only real preference I have.
The machine is going to be used for moderate amounts of gaming and media-related tasks (such as video encoding and capturing), in addition to normal everyday tasks (such as web browsing, watching movies, etc).
Edit: Due to my dumbassery, I forgot to mention two things:
1) All parts need to be purchased from Bestbyte Computers - as i don't have a credit card, or otherwise can't be arsed to do online shopping (security etc). This is the biggest, best, and most cost-effective store near me that's easily travelable.
2) I'm not planning to overclock, but I may in the future. Should I choose to, i'll upgrade to an aftermarket HSF. But in the meantime, with default clock speeds, and with the Antec 900's cooling, will the stock HSF be enough?
sorry for forgetting those two things.
Old September 16, 2008, 06:57 AM
Dashock's Avatar
Well what Ram are you interested in buying? You mention the speed and quantity but no manufacture.? And i see why your buying an Asus trying to fully utlize the EPU eh nice nice. I love my Asus P5q-E P45.
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
Old September 16, 2008, 06:59 AM
thanks, i edited it and added that in. but just to save you having to recheck; it's going to be 2 x 2GB sticks of Apacer.
MAIN RIG:
Case: Antec 900
CPU : Intel E8400 45nm Core 2 Duo @ 3GHz 1333MHz FSB
RAM : 4GB DDR2 800MHz (OCZ Platinum)
HDD : Main: 120GB SSD (OCZ) Media: 500GB (WD) Storage: 1TB (WD)
GFX : HD4850 (512MB)
PSU : 610W PC Power Silencer
MoBo: Asus P5Q SE
View : Acer H213H 21.5" @ 1920 x 1080
Oshawa Deathmatch Community -- An open group for Durham/Toronto Airsoft, Paintball, and Nerf players. Come join!
My Game Dev website: http://mikeseguin.webs.com/
Old September 16, 2008, 07:52 AM
JD JD is offline
I'd definitely recommend a Corsair power supply. I don't think that's one of Coolermasters good ones...
Also I'd go with OCZ, Corsair, Mushkin or G.SKILL RAM instead.
Oh and perhaps an aftermarket heatsink if you plan to overclock.
Old September 16, 2008, 08:53 AM
cwestwell's Avatar
I agree with the two previous posts definetly spend a little extra on Decent Ram and a good PSU. Apacer is cheap cheap and coolmaster is ok for replacement PSU's in a Dell or HP but for your own build go with a better unit that should not fail in the life of your PC and some more. My only other reccomendation is a bigger monitor the price difference beetween a 19" and a 22" is minimul. Believe me I also thought the whole I dont need anything to big and fancy a 19" Wide is lots of monitor. But then if you compare a 19" wide to a 17" standard it looks small. I went with a 24" and holy crap you will not regret the spending a little more for the extra monitor goodness. It's amazing how fast your mind will change from I dont need anything to big and fancy to holy crap how did I live without this.
_______________________________________________
E8600 420x10 |Thermalright 120 Black | Maximus Formula | ATI 4870X2 | 4GB Buffalo FireStiX PC8500 | Corsair HX1000 | Lian Li V2010B | Vista Ultimate 64bit
Q6600 334x9 |Thermaltake Blu Orb | ASUS P5Q-PRO| ATI 2900XT | 6GB Corsair XMS2 PC6400 | Corsair HX520 | Lian Li V600B | Vista Home Premium 64bit
Old September 16, 2008, 08:57 AM
I was also wondering, if you are going to overclock, there is no point in EPU enabled boards, since you aren't going to use that feature anyways.
Well why not go for a 4870 instead, I recenly read a review about a 4870 beating all 9800GTX, sorry to say but the 4870 had their butts whopped and handed to them.
Other than that what ^^ Jdrom said, Corsair 650w power supply really seems to impress, OCZ's and Corsair's are good sets, I personally like to settle for Mushkin or G-Skill, and Mushkin off course since they are very good sets, you have almost full support for help from HWC users and more importantly direct help from MushkinGreg, also with any Customer service or tech issues, he should be able to help you out.
Old September 16, 2008, 10:02 AM
cwestwell's Avatar
I believe hes going with the GT not the GTX the 9800GT is about $99 to $149.99 maybe the 4850 however they still cost a little more. It would certainly be worth it in the long run but that is yet another extra cost.
Old September 16, 2008, 10:22 AM
No I realise that, what is why I wrote 4850 or 4870, in his case 4850 for sure, a little more but well spent in the long run, better video card for sure, but you are right extra cost :(
Old September 16, 2008, 12:18 PM
Dashock's Avatar
Hey buddy em yea id suggest like some others here have im not familiar with that brand of memory but its because i was for years building with only OCZ memory but this time i went with Mushkin and love it id suggest going with any of the big names prices are pretty cheap now a days. Plus one for Mushkin or OCZ.
Miggs nothing wrong with an Epu board i can overclock with the Asus program up to 3.8ghz when i want and downlock down to 1.4-1.6 when im just using azureus and folding in the background. It saves a lot of time cause i try to conserve as much electricity as i can having 3 computers and a laptop in the house. I havent found any problems with it running on both Vista and Xp. I never really used any of these budled software but i really like this asus epu package might not be for everyone. But for ease of use and daily overclock/underclock its as eassy as press of a button! :p
Asus P5Q-E
Antec Spot Cool
Logitech X-230
Old September 16, 2008, 12:21 PM
sorry guys, my fault but i forgot to mention two things
MAIN RIG:
Case: Antec 900
MoBo: Asus P5Q SE
