Old August 10, 2017, 07:02 AM
great_big_abyss's Avatar
Default School Laptop - $500
My wife is going back to university as a mature student. Her old laptop is about 10 years old, and even with a few upgrades like Windows 10 and a hybrid drive, still feels sluggish and slow. Time for a new one.
Our budget is about $500, and our requirements are that it be good for university work. You know, document creation, project work, etc. So mainly Microsoft Office stuff. Therefore it doesn't have to be a powerhouse in the compute department. Ideally it should be comfortable to type on, and have a relatively decent trackpad. Build quality should be good enough for it to last at least 4 years (i.e. enough to get her through her program).
Any recommendations? We have a Memory Express here that I could purchase from.
Old August 10, 2017, 07:39 AM
Are you open to buy a refurbished or office resale laptop? Could be a good fit for your needs. They will be on the heavier side, but at a good price.
Back up - Ebay (Inik1) or Heatware
Old August 10, 2017, 08:13 AM
Could be open to it...
Old August 10, 2017, 08:20 AM
sswilson's Avatar
That's what I was going to suggest.
A second (or third) gen i5/7 paired up with an SSD would probably fit the bill. Any new sub $500 laptop would probably need an SSD to make it "pop" anyways.
edit: I bought an e6420 through newegg.ca which gave me a reasonable shipping price along with the comfort level that came with buying through the newegg marketplace.
Old August 10, 2017, 06:21 PM
3.0charlie's Avatar
I would recommend only the Lenovo Thinkpad line. It's got to be sturdy, hinges must not fail - every single customer of mine that chose either was very pleased.
And yes, refurbs are a possibility. Definitely drop a SSD though in place of the HDD for the sake of a better power consumption and data safety.
Example: https://www.walmart.ca/en/ip/lenovo-.../6000196571794 Already with a SSD!
Hydro-Quebec is salivating...
Old August 11, 2017, 05:29 AM
A member here just recommended to me a website with nothing but refurbished business laptops. Lots of 3-5 year old Lenovo thinkpads on there for $400 or less. Some of them come with 128GB SSD's. They sound perfect.
Like this one: https://ca.refurb.io/collections/lap...600x900-laptop
Has an i7, 8GB of RAM, and a 128GB SSD. Perfect!!! There are a few with i5's, 4GB of RAM and an SSD for $250, too, if we're feeling particularly cheap.
Old August 11, 2017, 05:35 AM
sswilson's Avatar
8GB is probably the minimum you'd want, but you should be able to find that on kijiji/craigslist for $30 - $40 if the model you choose only has 4GB.
Old August 11, 2017, 05:44 AM
Oops, that first one is out of stock.
Here is one with an i5 2520m, 8GB of RAM, 128GB SSD and Win 10 Pro for $325!!
https://ca.refurb.io/collections/len...0-professional
Old August 11, 2017, 05:59 AM
I bougth a couple of months ago from refurbio. I bougth it through their ebay outlet
Lenovo ThinkPad T420 i7 2640m 2.8ghz 8GB Ram 128GB SSD 1600x900 Windows 10 Pro, Grade A
It was 390$ all in.
My sister is very with it!
Old August 11, 2017, 06:28 AM
It was 390$ all in.
Any bloatware installed on it? Or was it a clean windows install?
EDIT: Just heard back that a laptop bought from here did NOT come with bloatware installed, but rather a clean install of Windows. This pretty much seals the deal for me. I'll be searching for an appropriate laptop from refurb.io when the times comes.
Looking for a Laptop for School AKAThink Mobile Computing 2 September 19, 2014 12:06 PM
Laptop for School ZereoX Mobile Computing 6 August 31, 2010 02:22 PM
Laptop for School... And gaming AmuseMe Mobile Computing 16 June 30, 2010 09:00 PM
Laptop for School JD Mobile Computing 9 June 9, 2008 06:29 PM
Finding a laptop for school Amon Troubleshooting 11 August 23, 2007 09:34 AM
