Old July 10, 2014, 08:43 PM
Default Note 2 stuck at boot screen
Someone asked me to fix their Galaxy Note 2, it gets stuck at a boot screen and gets the frozen loop when trying to charge it.
I can't get into the hard reset menu/recovery mode but I can get into ODIN. I tried loading the stock firmware onto the phone via ODIN but the micro USB connection craps out.
Anything else I could try?
Old July 10, 2014, 08:53 PM
Samsungs have a very good built in fail-safe to force the hardware into download mode using a USB jig with a resistance of 300K.
I made one years ago and used it frequently back when I was flashing my phone all the time.
You can find instructions here: How to make Samsung Galaxy S Download Mode JIG to solve if 3-Button combination failed | Android Solution.
It should still work for other Samsung phones.
Failing that you can just buy one off Amazon or eBay, but that's a waste of money.
If you want you can just swing by Mississauga and I'll let you have a go at using my jig.
Also ensure that you're using a good quality cable when flashing, I've had failures before on cables that I used to transfer data quite frequently, then switched to other cables and had success. I tend to use manufacturer's cables for updates.
Old July 11, 2014, 07:57 AM
b1lk1's Avatar
Agreed here, I've had major issues wit HTC phones and generic USB cables.
DAILY: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 270 2GB/128GB SSD+750GB HDD+2TB HDD
Newly Build System gets stuck on Starting Windows screen? syaoran7li CPU's and Motherboards 38 April 25, 2013 08:20 PM
[Solved] - Computer stuck on 'ASUS' splash screen MittWaffle Troubleshooting 14 August 28, 2010 02:14 PM
new build, black screen on boot UberMoo Troubleshooting 11 February 7, 2009 06:09 PM
Screen dosnt boot CactusJoe Troubleshooting 13 January 27, 2009 04:28 PM
Blank screen on boot? Matt Troubleshooting 0 January 22, 2009 04:57 PM
