Old March 29, 2014, 10:20 AM
Default Macbook Pro, 2006 + Vista Bootcamp = Malfunctioning heat sensors
Hey Guys,
As the title reads, I have an older Macbook Pro (2006) which is running a bootcamped vista OS. I installed "Macs Fan Control" by CrystalIdea right away before installing windows updates/drivers/programs or the bootcamp drivers, so that I may first overcome the overheat issues that many have after bootcamping their MBP's. Everything in this fan control program was accurate including temperatures, and I could set the RPM's for anywhere between 1000-6000RPM either constantly, or dynamically based on specific diode temperatures in the MBP. Everything is great so far... right?
I installed windows updates and drivers without any issue, and after a few reboots, the fan control program still depicted accurate temperatures across the board, and set the fan speeds accordingly. I then threw in the Mac OSX DVD and installed the bootcamp drivers. Everything works seamlessly (bluetooth, isight, back lit keyboard, sound, etc). Only One thing is now way, wayyyy off.
Temperature readings. Unfortunately, I have no longer have accurate temperature readings for the system to reference, and set the fans RPM accordingly to. Most of the sensors now show 0C, and the others show 32C, than quickly spike to 64C, and back to 32C. The only accurate temps, are the hard drive, and the Intel Core Duo T2600 (as shown below in the pic), but I cannot select the T2600's temps as a reference.
The fans in "Macs Fan Control" say that they are running anywhere from 1000-16'000RPM (Which I'm not sure is even possible) Also, now in the fan control, the minimum threshold I can set my fans to is 10'000RPM, rather than 1000RPM. I double checked the readings with HWMonitor, and they too depict goofy temperatures.
This seemed to have happened as a result of installing the Mac OSX bootcamp drivers. I can live with the inaccurate readings, but the Macbook will certainly overheat if I don't give it an accurate sensor to reference it's fan control to. I could let it run at full RPM's 24/7, but I would rather not wear out the fans. This puppy is old enough as it is.
Any Idea's?
Old March 29, 2014, 01:01 PM
Nodscene's Avatar
First thing I would try (if you haven't already) is to uninstall the program and then install it again to see if that fixes thing.
Create something idiot proof and they will make a better idiot.
Intel Q6600 - Gigabyte EP35-DS4 - OCZ Reaper 4gig PC2-6400 - XFX 8800GT 512Mb Alpha Dog - AuzenTech X-Fi Prelude - Alesis M1Active MK2 - Corsair HX-620 - Silverstone Temjin TJ05B-X - Scythe Katana 2 - WD Raptor 150Gb - Seagate 7200.11 750Gb x2 - Samsung SH-S203N
bootcamp Win8 grinder O/S's, Drivers & General Software 5 February 12, 2013 12:48 PM
iMac 2006 upgrade draemn Mac 6 March 18, 2011 10:16 PM
PhII 955be wonky sensors? sswilson CPU's and Motherboards 11 September 29, 2009 12:53 PM
Fan Control and temp sensors. chibi_man Water Cooling 3 October 4, 2007 07:16 PM
HardwareZone list the best products of 2006 Supergrover Press Releases & Tech News 0 December 27, 2006 04:12 PM
