Old March 10, 2014, 02:53 PM
Trial Member
Default Wireless Charging?
Anyone use it? Care to comment on charging pads? I use a Nexus 5 and my lady uses a Note 3. I picked up the Note 3 charging door (i lul'ed at Samsung users and their add on$) and now need a round of pads. I looked at the samsung branded charging pad, but was wondering if one of the cheaper ebay china ones would work with both phones as i will need nearly 6 of them. Any feed back on these cheap-o ebay joints overheating, bad news etc?
Old March 10, 2014, 06:30 PM
JD JD is offline
I'd be very careful with the cheap ones and try to find solid reviews on them before buying.
I myself have the original Nexus orb charger from the Nexus 4 launch. Worked great with the N4 and now the N5. No issues.
Why do you need 6 chargers with only 2 phones? The assumption is you'd place this in an area where your phone typically resides, either at your desk or at your bedside. The N5 and Note 3 should both be able to survive a day on battery power without issues.
UPS not charging t0m Troubleshooting 23 January 21, 2018 05:03 PM
Charging problems Skozaa Troubleshooting 3 March 22, 2012 11:48 AM
Plugged in, not charging punk_zappa Troubleshooting 8 September 3, 2011 12:22 AM
is there any benifet upgrading router from wireless g to wireless N? Shadowmeph Networking 4 April 26, 2011 07:12 AM
Shaw charging overages, Telus is not - on CTV news. ipaine Networking 64 January 30, 2011 05:34 PM
