Old November 15, 2013, 02:55 PM
Caldezar's Avatar
Default Streaming media on Android
I just picked up a new (2013) Nexus 7, and I'm looking for the best way to stream movies and TV from my network shared NAS. (D-Link 323) It's a straight network share with no GUI or XBMC setup. I'm assuming I'll have to dig through the apps for something that will accommodate. Setting up XBMC (or any other media server) at this point is NOT an option. I need it to be simply between the NAS and the tablet.
Thoughts from Android users?
Old November 15, 2013, 03:12 PM
chrisk's Avatar
Folding Captain
I use Plex media server, but the phone app cost a few bucks though. I can then access the media from anywhere I have data.
Fold for team #54196
Old November 15, 2013, 03:27 PM
Caldezar's Avatar
Hmmm... this sounds perfect for me. I'll look in to it for sure. I also saw some reviews for OPlayer and was going to check that out as well.
Old November 15, 2013, 07:14 PM
I have Plex as well, but also use Archos video player which can stream off shares quite easily.
Old November 15, 2013, 08:23 PM
JD JD is offline
+1 to Plex as well.
Though if all your NAS has is a basic DLNA/UPnP media server, then using a combo like BubbleUPnP and BS Player also works great.
Old November 16, 2013, 07:43 AM
Varroa's Avatar
Plex, it will also transcode on the fly for non-supported android formats and it can also shrink files in real time to make them easier to stream. ie, if you have a 30GB mkv dolbly digital Bluray rip it will convert it to a stereo mp4 and stream it at 720p for example. I have plex on my Windows Home Server and it does a great job of this.
GAMER: Win10 Pro x64, I7 3770K (4.7Ghz) (corsair H110i), Asus P8Z77-V Pro, EVGA GTX 1080 FTW, Gskill 2 x 8 GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Crucial M500 480 GB SSD, Mx 500 SSD, HX750W, Sound blaster Z, & Fractal Design Arc MIDI R2
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
Old November 16, 2013, 08:24 AM
Arinoth's Avatar
Originally Posted by JD View Post
+1 to Plex as well.
Yeah I use BubblePPnP with Mx Player as it can support mkv playback (which at the time last year or so it was the only one that consistently would play any media file I had on my network)
Here I am: here I remain
Old November 16, 2013, 02:59 PM
JD JD is offline
When I tried, MX Player didn't support DTS audio, but BS Player did.
Old November 17, 2013, 11:45 AM
Caldezar's Avatar
So far, Archos has actually been working great. Although Plex does seem to be abetter product, so I may try it in the future if Archos runs in to any issues.
Old November 27, 2013, 04:30 PM
sswilson's Avatar
So does bubbleupnp need to be running in order to get access to the dlna content? Not completely sure how this works but I'll continue to play with it. (Or I'll just break down and buy a 32G micro ssd for my music files.... ;) ).
Android to Android remote desktop? biff Mobile Computing 4 July 28, 2013 09:26 PM
Android performance doubled; coming to CM9 soon [Talk Android] chrisk Mobile Computing 3 June 11, 2012 03:58 PM
Media Streaming... Hail Ceasar Networking 8 November 19, 2011 07:32 PM
win media player can play vid but win media center cant Shadowmeph HTPC Systems & Software 0 September 5, 2011 07:52 AM
