Old September 25, 2013, 11:47 AM
odis172's Avatar
Default US/CAN data roaming
I'm trying to find a solution that will enable mobile data connection while travelling around Canada and the US. I was thinking integrated WWAN card in an hp elite 9470m laptop. I want to plan for 10GB/month, but Rogers doesnt offer a roaming data plan, and bell said it would be 250$/month for 5GB - with an insane fee for going over the 5GB. I'm thinking that leaves me with having to get a seperate data plan for the states. Any suggestions on providers, or an alternate way to do this?
Laptop: Lenovo T420 - Core i5 2520 - 8GB DDR3
Server: 2 xeon E5530 - Asus Z8N-D6 - 12GB DDR3 - 8x 500GB raid 50 - Perc 6/i - Compucase RA448A00
Old September 25, 2013, 11:53 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Roam Mobility.
chrisk's Avatar
Folding Captain
I used Roam Mobility this summer. It uses T-Mobile's network and I found that coverage was spotty at best while driving in remote areas in NE States, but was fine in the cities:
Travel Free from USA Roaming Fees - Roam Mobility
edit: skyninja'd
Fold for team #54196
Old September 25, 2013, 12:16 PM
krazyups's Avatar
I'm going to have to go with something like this in the near future, as my office will be transferred to Michigan, forcing me to commute across the border for work. That, and I won't be issued a company cell, so I'm SOL if my wife or other family members need to contact me and I'm away from my desk (or don't call my desk phone to begin with, like my wife).
Currently just using pay-per-use, so it'll be a steep increase from the ~$20 or so I'm spending per month.
Old September 25, 2013, 02:10 PM
odis172's Avatar
Roam seems pretty good, looks like its a maximum of 5GB/month though.
Old September 25, 2013, 08:23 PM
odis172's Avatar
Looks like they use the T-mobile network, so it wouldn't work in Canada. Looking for something that allows for seamless travel around US and CAN.
Old September 25, 2013, 10:56 PM
Honestly, you're much better off getting 2 separate accounts, one with an american provider and one with a canadian provider and taking the time to swap out.
Old September 26, 2013, 04:13 AM
chrisk's Avatar
Folding Captain
I really hope I am wrong then, but you will be stuck paying the high costs from Bell, etc. if you want 'seamless.' Perhaps retentions dept or something from Bell or Rogers will be able to help, or you can pray that the govt. CRTC comes up with something (saw something rumoured about the govt doing something about roaming fees but don't count on it).
Another option for you is a dual sim phone. They are popular in Asia/emerging markets but not easy to find from carriers here so you are likely to need to purchase a phone outright. You may want to do some research on carrier compatibility as well if you go the dual sim route, especially if LTE and such are important.
Old October 11, 2013, 02:24 PM
chrisk's Avatar
Folding Captain
This looks very compelling:
KnowRoaming aims to disrupt travelling with a brilliant little SIM sticker | MobileSyrup.com
It works by interfacing with your unlocked phone’s baseband — yes, your phone must be unlocked for KnowRoaming to work — with a tiny piece of software on the chip itself. When you get to another country, the sticker will elect to become the primary SIM card in your phone, interfacing with local carriers at rates far better than your Canadian provider’s.
The KnowRoaming team has negotiated agreements with network providers in nearly every country that offers voice, text and data services, and while prices are pay-per-use, the SIM merely needs to be loaded with funds (which never expire, unlike many local prepaid SIMs) through the companion apps.
Old October 13, 2013, 05:20 AM
MARSTG's Avatar
Starting December 2nd there will be a max limit of 100$ for data roaming fees in US. But I guess will be applicable only to the new contracts. Ask your carrier for details.
Historical Data Rison HardwareCanucks F@H Team 1 April 7, 2012 07:49 PM
A-data SSD firmware is out gingerbee O/S's, Drivers & General Software 0 December 9, 2009 10:43 AM
Data every where gingerbee Off Topic 11 October 17, 2009 03:25 AM
A-Data RAM zlojack RAM 11 December 7, 2008 03:22 PM
EFA DATA????????? rob123 O/S's, Drivers & General Software 5 July 3, 2008 06:27 AM
