Old August 29, 2013, 03:34 PM
NyteOwl's Avatar
Default Help with an older Thinkpad
I have an older IBm Thinkpad A20MN that has worked fine up to this point. The problem only showed up about a month ago after a MS Windows update (not sure if that had anything to do with it or just coincidental timing).
Recently, when conencted to it's dock or AC it starts to restart itself. That is to say it shuts off, restarts, gets partway through start up asnd restarts. The longer this goes on the shirter the space between restarts.
Now the fan is running as I have it configured for full CPU speed when on AC and the bottom is very very warm so I suspect it is a heat problem as if the system is started on battery and remains on battery it does not exhibit the problem unless really stressed. Unfortuantely, it seems doing a Windows update is stressful (no smartass commens please :) ).
I though I'd try taking it appart and seeing if it needed a good cleaning but am at a loss as to hoew to get the case apart. I removed every screw that could nbe considered holding the damn thing together (including the ones hidden under rubber pads) and it still won't separate.
Any help or info would be appreciated.
Obsolescence is just a lack of imagination.
Old August 29, 2013, 03:54 PM
sswilson's Avatar
Disassembling IBM ThinkPad A30 Motherboard - iFixit ?
Not sure if it's the same procedure that requires access to something under the keyboard (this is an A30 apparently), but that would be my guess as to the problem you're having getting it apart.
Old August 30, 2013, 03:55 PM
NyteOwl's Avatar
Thanks I'll have a look at that and see if anything comes from it.
Old September 4, 2013, 07:48 PM
NyteOwl's Avatar
Still can't seem to get it apart and I'd hate to break it, in case it's nothing major that's actually wrong. Sadly the locak IBM service rep has ceased business.
Lenovo ThinkPad Twist TheRealAndyCook Mobile Computing 2 June 15, 2013 08:53 PM
[WTB] Thinkpad T500 Borg Buy/Sell & Trade 0 August 27, 2011 04:36 PM
FS >> Thinkpad X61 Tablet blindfury Buy/Sell & Trade 21 November 3, 2008 10:34 AM
Thinkpad T60 2007VN1 night_rider Mobile Computing 1 January 30, 2008 02:18 AM
