  #21 (permalink)
Old July 28, 2013, 08:57 AM
JD JD is offline
Yeah, I guess I've never had 4h+ screen on time on my phone, simply because I don't use it that much. Usually it just sits in my pocket while at work for 8h and I only really use it during my commute to and from work to read the news and such, which is about 2h in total. Typically speaking when I get home I still have around 75% battery life. This is CM nightly 07/19 with faux123 beta kernel 17b02, it's been the same with previous builds too though.
  #22 (permalink)
Old July 28, 2013, 08:58 AM
Originally Posted by Arinoth View Post
What's weird as it sounds like I get more screen time on my SGS1 then the Nexus 4.
I've also found that I had an issue being able to get my SGS1 to recharge to 100%, I let it run down below 10% (usually never let it go under 50 or 40% if I can help it) as I was using it heavily as a GPS to find how to get to apartments we were looking it. When I got home I plugged it in and it charged back to 100%, so it may be the fact your battery isn't discharging all the cells, causing some to not be able to be fully re-charged, though that's necessarily relevant to what phone does Arinoth want, oh well.
This is normal behavior for android. Even my S2 does this.
  #23 (permalink)
Old July 28, 2013, 09:01 AM
Arinoth's Avatar
I have been reading that all Nexus phones are unlocked from the get go, which gives it an easier ability to be sold and a newer/new phone to be bought and used (if it too is unlocked like the N5)
Here I am: here I remain
  #24 (permalink)
Old July 28, 2013, 11:29 AM
That's correct, the Nexus line up is unlocked, but to be honest, unlocking phones is really cheap and easy for everything other than an iPhone.
  #25 (permalink)
Old July 28, 2013, 11:30 AM
Arinoth's Avatar
So the camps so far are then Nexus 4 (and wait/upgrade to Nexus 5 when it comes out) or the Samsung S4 (on a 3 year plan at 250 or a 2 year plan for 450)
  #26 (permalink)
Old July 28, 2013, 11:43 AM
supaflyx3's Avatar
Honestly, unless you want a bigger screensize, or if they put in a removable battery in the nexus 5, you probably wouldn't have to upgrade. The N4 is still really fast, the S4 or HTC One aren't really faster than it with just general phone usage, they just have more features.
  #27 (permalink)
Old July 28, 2013, 11:57 AM
Arinoth's Avatar
What's the main feature differences between them all then?
  #28 (permalink)
Old July 28, 2013, 12:27 PM
supaflyx3's Avatar
The S4 and HTC have IR blasters, S4 has removable battery and SD card, and both of them have better camera software. But you have to deal with their skins and slow updates.
  #29 (permalink)
Old July 28, 2013, 01:14 PM
Arinoth's Avatar
Well I'd be running a custom ROM on whatever one I'm using. I've never really used the SD card on my SGS1 nor have I gotten close to fill up 8GB on it. I also don't really use my phone to take pictures, that's what our digital SLR is for.
  #30 (permalink)
Old July 28, 2013, 01:24 PM
supaflyx3's Avatar
Check out Koodo, they have outright price for $300 for the 16gb nexus 4, or if you have telus in your area they have decent plans.
Wind Mobile phone options moocow Mobile Computing 20 October 13, 2011 10:24 AM
best vfm mobile phone neojjjk Off Topic 8 September 8, 2011 07:19 PM
[WTB] wind mobile compatible phone ITaoI Buy/Sell & Trade 0 December 20, 2010 08:24 AM
[FS] Rogers Razr2 V9 Mobile Phone 3G DunF88 Buy/Sell & Trade 0 August 16, 2009 11:06 PM
Motorola's mobile smell-o-phone Supergrover Press Releases & Tech News 2 April 14, 2007 08:33 AM
