Old May 4, 2013, 01:22 PM
nasrott's Avatar
Default S4
Picked up the new s4 friday like it so far, be needing an microsd, any preference as too which one to get from CC ie: are some faster than others or is class 10 fine idea on any make?
Old May 4, 2013, 02:55 PM
FreeKnight's Avatar
I think as long as it's class 10, you don't need to worry past that. Maybe some minor variation between brands, but I know I used G.Skill, Sandisk and one other brand (kingston i think) 32gb cards in my s3 to watch 720p videos and there wasn't a single one that stood out as faster than the others, they all played pretty much instantly and there weren't any issues.
Old May 4, 2013, 03:10 PM
nasrott's Avatar
Was thinking that the 16 gig plus msd would make this a supetphone but now have been reading that the msd can only be used for certain things nothing to do with google not apps, not games, seems only thinga like video shot with the phone and some pictures can go into the msd rest demands the on phone space. Wow not sure what to think of this.
Seen some articles on the web in regards to this.
Does your s3 inforce only certain things go into your sd card?
Old May 4, 2013, 10:49 PM
dustin1706's Avatar
You are correct. Android only allows apps to be installed on the phones internal memory. However the SD card can be used for taking pictures, recording video, storing music and movies, downloading etc. The onboard camera isn't fast enough that the performance between different class 10 cards will be noticeable.
MSI GT72 6QE-033US - 6700HQ, GTX980M, 1080p G-Sync IPS, 16GB DDR4, 1TB Evo 850 SSD, 256GB Toshiba SSD, 2TB Barracuda, BD-Rom/DVD-RW
Old May 5, 2013, 03:33 AM
nasrott's Avatar
So music which is my largest folder can all go onto the msd then theoretically have 60 gig of music and vids there leaving on board space for apps and what not.
That works for me.
Old May 5, 2013, 07:14 PM
I can see why they are using an internal only policy though - it provide more consistent, more reliable performance. - Unfortunately manufacturers are going to have to catch up with this quickly.
I assume there's going to be a one-click workaround soon enough though.
Old May 5, 2013, 07:25 PM
nasrott's Avatar
Already is which allows apps to be installed on the msd. Will see if I can find the link
http:// http://api.viglink.com/api/c...13678072357586
Old May 5, 2013, 07:32 PM
nasrott's Avatar
Has been allot of talk about using api instead of going the root method that leaves biulds valnurable bcause Su is out.
