-   Mobile Computing (https://www.hardwarecanucks.com/forum/mobile-computing/)
-   -   Any such app or sensor device for iPhone 4s? (https://www.hardwarecanucks.com/forum/mobile-computing/60403-any-such-app-sensor-device-iphone-4s.html)
taimoorali007 March 26, 2013 09:18 AM
Hi, hope you all are fine there. I read somewhere about iPhone that it can do almost any engineering related task. I dont know that its only in movies or real *:p
Is there any sensor product or app for sensing gas pressure from pipeline??
Plz if anyone know something about it then inform me. I can spend $$$ on it.
Thanks.
muse108dc March 26, 2013 11:10 AM
The sensor would be for the pipeline, would need the ability to wirelessly transmit (guess in theory Ethernet would also work) and would require an app to display the data on the iphone. In theory its possible but I have not seen one.
taimoorali007 March 26, 2013 12:11 PM
Hmm thnx. Atleast its real :P
Ok I'll look for it, some sources you can provide on internet?
taimoorali007 March 26, 2013 12:25 PM
Hey!!! I found somewhere. The cable which is 30-pin to VGA is the best source. So it is possible that sensor should be purchased that have feature on VGA output, it then can be plug to iPhone for readings. BUT my question is which app would be required as every sensor doesnot have its iphone supported app?!
