-   Mobile Computing (http://www.hardwarecanucks.com/forum/mobile-computing/)
-   -   Best laptop (http://www.hardwarecanucks.com/forum/mobile-computing/60116-best-laptop.html)
4TeamG March 11, 2013 01:59 AM
Best laptop
Hi guyse , I wonder which laptop should i take :
HP ProBook 4540S Gamer's Edition / 15.6" / Intel Pentium B980M / 4GB / 750GB / Radeon HD7650 2GB !!! / USB3.0 / Linux
Or
ACER E1-571G 15,6" / Intel Core i3-3110 / nVidia GF620 1GB / 4GB / 500GB / 6cell / 2-in-1 / 0.3Mpix / LINuX
Or
HP PAVILION G6-2284SR /INTEL PENTIUM DUAL B980 /4GB / 500GB /15.6 /HD7670M 1GB /6-CELL BATTERY
Laptop will be used for gaming , network surfing and ect .
Give me best choice ,guyse. :biggrin:
dandelioneater March 11, 2013 08:58 AM
the probook looks to be the better laptop for gaming. You need decent video to run games on a laptop and the probook has that mid range card 7650 card. the 620 isnt really a gaming card.
4TeamG March 11, 2013 09:12 AM
Originally Posted by dandelioneater (Post 695669)
the probook looks to be the better laptop for gaming. You need decent video to run games on a lapp and the probook has that mid range card 7650 card. the 620 isnt really a gaimng card.
Well , i know that I3 is a lot faster than B980 ...
But... What would YOU choose ?
4TeamG March 14, 2013 10:40 PM
Thanks for nothing ,guys , thanks for nothing ...
JJThomp March 14, 2013 10:47 PM
Honestly most of us would probably pick none of them, if you give us a budget we could help you more because none of those are a very good option.
4TeamG March 15, 2013 10:18 AM
Okay then ...
600$ budget ...
Keltron 3030 March 15, 2013 11:16 AM
What games are you gonna be playing? Do you want the bare minimum experience, or do you wanna be able to crank up the details?
For your budget, I would look into something that has an AMD APU, and if it had a discrete GPU for crossfire, that would be a huge bonus.
Something along the lines of this might be just what you're looking for:
Newegg.ca - lenovo IdeaPad S405 (59342927) Notebook AMD A-Series A8-4555M(1.60GHz) 14" 4GB Memory 500GB HDD AMD Radeon HD 7600G
This won't run max settings on high end titles, but should be just enough to play them at a comfortable eye-candy level
