Old January 30, 2013, 01:12 PM
bigFOIG's Avatar
Was looking for some more options in terms of x86 tablets. Asus Vivotab, Acer Iconia W700, and Samsung Ativ Smart PC seem to all hit the criteria. The Samsung looks particularly interesting... Just some suggestions for anyone looking for a full Windows tablet.
Old January 30, 2013, 01:26 PM
botat29's Avatar
I own a MacBook air and it's a 13" I purchase it in November when I already have a good idea of the spec of the Surface pro. I will not get a smaller screen for sure.
Old January 30, 2013, 02:14 PM
JD JD is online now
The Acer W700, while having better battery life, doesn't have pen-input and it's keyboard solution isn't as clean as the Surface Pro, especially for travelling.
We also had a Surface RT at work too (for a VP) and it looked like a decent device. It was a bit clunky though and the Surface Pro is even thicker/heavier. You'll likely want to find a MS Store to go take a look at it first before buying.
I'm personally not sold on Windows 8 tablets currently. If you honestly see yourself using it in tablet mode frequently, then go for it. Otherwise, stick to the tried and true laptop design.
Microsoft Surface muse108dc Mobile Computing 15 October 31, 2012 02:18 PM
Surface to Launch With Windows 8 on October 26 Sam_Reynolds Press Releases & Tech News 7 July 30, 2012 06:35 PM
Microsoft Surface Arinoth Press Releases & Tech News 12 June 21, 2012 10:28 AM
When did this baby surface? Jamula66 CPU's and Motherboards 1 August 24, 2010 06:06 AM
Scratched Surface idno3 Air Cooling 9 August 14, 2009 11:05 AM
