-   Mobile Computing (http://www.hardwarecanucks.com/forum/mobile-computing/)
-   -   reboot/restart issues with ICS stock and JB ROM (http://www.hardwarecanucks.com/forum/mobile-computing/58930-reboot-restart-issues-ics-stock-jb-rom.html)
punk_zappa January 4, 2013 02:58 PM
Phone is LG Nitro HD. I got it last March with Gingerbread and updated to ICS in September. Everything was fine for a couple of weeks then reboot or BSOD started happening. Sometimes once every 2-3 days then it got to 3-4 times a day, sometimes just sitting by itself and sometimes while texting or using other apps. I would factory reset it and it would help for a week or so. It was sent for repair but I think they just did a factory reset which helped for a couple of weeks and then back to BSOD or reboot.
I got fed up with it 3 weeks ago and installed a CM10.1 based ROM, in Alpha, but same symptoms. There are times, when phone was in my jacket and I walked the dog and I try using the phone as soon as I got in the house it would reboot (or anytime it got cold).
Any of your Android phones have these symptoms? I am thinking of just reverting to Gingerbread to be at least fully functional, never had a reboot with GB. My wife's Note 1 had battery issues after updating to ICS but that's been fixed after a few factory resets and hers work just fine.
LarkStarr January 4, 2013 08:43 PM
Post over at XDA too, see if there is a thread there already about it, but I have a feeling you have a hardware issue. Try to go back to gingerbread for the time being to see if you still have these issues. Sounds quite strange. Did you do a complete wipe of the data and caches when you updated to 10.1?
enaberif January 4, 2013 08:52 PM
You didn't say how you flashed the rom but when you do it needs to be properly.
Meaning wipe and start fresh.
punk_zappa January 7, 2013 11:16 AM
I've been checking XDA for a while now and it is a common issue with this phone. Yes, ROM was installed correctly, wiping the caches. I will try to use other ROMs and see if it cures itself.
I wasn't looking for answers but just to compare with other phones if this issue exist after updating to ICS. Thanks.
