Old October 31, 2012, 08:59 AM
Custom rom should come in a zip file. Make sure anything you have on the phone which could be important is backed up then in twrp format /cache and /data which will essentially wipe the phone. Then install the custom rom from within twrp and should be good to go.
After you have a custom rom installed check to see if there is a possible kernel to install as well to help even further with things like performance and battery life.
Old October 31, 2012, 10:24 AM
Nodscene's Avatar
Sounds good. As there is basically nothing in the phone now I think I'll just go ahead and see what happens.
Create something idiot proof and they will make a better idiot.
_____________________________________
Intel Q6600 - Gigabyte EP35-DS4 - OCZ Reaper 4gig PC2-6400 - XFX 8800GT 512Mb Alpha Dog - AuzenTech X-Fi Prelude - Alesis M1Active MK2 - Corsair HX-620 - Silverstone Temjin TJ05B-X - Scythe Katana 2 - WD Raptor 150Gb - Seagate 7200.11 750Gb x2 - Samsung SH-S203N
Old October 31, 2012, 11:07 AM
Nodscene's Avatar
Ok, it's been updated with Liquid Jelly Bean. So far so good. Had to download and install Gapps though as that wouldn't load but everything is running so much better. Screen flickering is gone and its very smooth right now. It also remembered all my settings even after wipe so either I did something wrong or it's supposed to do that haha. Just have to make a test phone call to ensure that works.
Thanks for all your help. Now the hard part is finding good programs for what I need.
Old October 31, 2012, 11:39 AM
Installed go launcher and go locker right off the bat.
Have no Clue how to FOLD:P Soullessone21 HardwareCanucks F@H Team 20 March 28, 2012 01:15 PM
No clue what these parts are! Please help ID'ing them jcmaz Off Topic 10 August 4, 2011 04:26 AM
I have know clue how to overclock my CPU Shadowmeph Guides & How-to's 14 February 15, 2009 07:49 PM
Tons of hdtvs, no clue which to choose Jonwall Display Units 13 December 26, 2008 05:38 AM
On a happier note.... sswilson Off Topic 59 December 20, 2008 08:47 PM
