Old July 8, 2012, 02:48 AM
Default How to know if a smartphone is okay?
Hi guys. This is perhaps a weird question but I have a Windows Phone and I'm pretty sure it's okay, but as with any smartphone it doesn't have any virus protection (as far as I know).
We browse the internet with our smartphones as we do with our regular computers so how can I know if my phone has picked up something on the way? It if it has, can it be fixed?
In general what I'm trying to say is that I'm very pleased with my phone and would like it to continue working like it was new without starting to be slow or do weird stuff or something like that.
Thanks! :-)
Old July 8, 2012, 03:29 AM
Galcobar's Avatar
Quite a few anti-virus applications from the big names for Windows Phone 7 available, some free or trial versions, and some available in the Windows Marketplace.
Old July 8, 2012, 07:07 AM
Thanks! :-)
Have you installed "3D Anti-Terrorist"? If not, you probably don't have a virus, a few minutes of Googling only turned up this single trojan.
If there are any problems, you can get perform a factory reset in the settings menu to return to factory settings. In general, this shouldn't be necessary; apps are sandboxed, so uninstalling leaves the phone in the exact same state as before an app was instaled.
I don't think there are any anti-virus apps available anymore, AVG got pulled after some controversy about it being useless (no real WP viruses, and the app is sandboxed so it can't really scan anything anyway), and it using geo-location to track users in a way specifically disallowed by WP certification guidelines.
Old July 8, 2012, 07:19 AM
Meh your over worrying.
Virus protection on a smartphone is personally just a waste of resources for the phone.
Old July 8, 2012, 09:05 AM
I have no such thing as 3D Anti-Terrorist on my phone. :-) I know I probably had nothing to worry about but I just wanted to ask anyway. However, it is good to have the factory reset as an opportunity, just in case. Though I doubt it'll ever be necessary. Thanks guys!
Old July 8, 2012, 03:38 PM
Galcobar's Avatar
Kaspersky at least has an anti-virus download still available: Kaspersky Mobile Security
Old July 8, 2012, 04:12 PM
That's for Windows Mobile (which actually has viruses), which was superseded by Windows Phone and abandoned several years ago.
Old July 10, 2012, 12:47 PM
crazyea's Avatar
Stay off the pr0n and you're good!
But seriosuly I wouldnt worry about it. Just keep a back up of your contacts, etc and restore if needed.
HeatWare: CrazyEA
Old July 11, 2012, 12:24 AM
Galcobar's Avatar
Ack, quite right.
Cheapest Smartphone? Borg Mobile Computing 14 October 31, 2011 04:24 AM
Smartphone lcdguy Mobile Computing 10 September 13, 2010 05:18 AM
Need a Smartphone Arinoth Mobile Computing 43 September 1, 2010 01:43 PM
which smartphone to get? ragenrok Mobile Computing 23 June 24, 2010 12:51 AM
smartphone slow down tzetsin Troubleshooting 9 April 25, 2009 12:27 PM
