Originally Posted by enaberif I would still choose the Galaxy S2 over the S3 but if it was between the S3 and the Nexus I would take the S3.
Nexus is running ICS which the S3 will have soon as well.
16gb believe it or not is a lot for a phone unless you plan on storing umpteen amount of songs and videos its all you need. I have a SD card in mine just because I had a spare lying around. |
Why would you take the S3 over the S2? The S3 is better in every way
And I'd go for the S3. If you don't like the UI, change it. They're very easy to root/ install custom roms, etc. There's going to be TONS for the S3.
You can also change the UI quite a bit with just a different launcher and messaging app, which you don't need to root to do.
