Originally Posted by belgolas hmm thats not good as I travel a lot. Wondering when it will get patched
Well I might as well wait some more as my iPhone 4 still works and it will get cheaper for me the more months I wait. |
Not sure about a patch. All I can say is that with my Galaxy Note, the issue was present in April when I got it, and was present on all the ATT roms I tried with the phone.
The telling clue for me is that with all the various Note roms, to disable LTE I had to use a dialer code and then select the right config on my own. On the Bell modems, disabling LTE automatically is very easy (now why would they do that.....)
On the flipside, disabling LTE gets drastically better battery life, and for most tasks, I don't see any benefit of LTE.
If LTE is important to you (despite the lower battery life), then I would look to something other than the latest Samsung phones unfortunately on Bell's network.
However, if you can live without LTE like me (and enjoy the better battery life like I do), then the S3 is still a great phone.
The Galaxy Note II is also going to be released in late August. It will probably have a quad core and LTE, which is novel right now. Maybe the radio/modems will be better on those.
For more info on this issue, check out the Bell forum on HowardForums as we have a discussion or 5 on it. Also, there is the odd thread on XDA and AndroidForums too.
