Old June 4, 2012, 12:27 PM
bissa's Avatar
Default installing busybox on an unrooted phone?
I want to install busybox on my S2, but I don't want to root the phone. does anyone know if this is possible?
I found a guide where you can install a homebrew version of it, but I want to install the version that people are familiar with.
Old June 4, 2012, 01:18 PM
you need to root regardless and its a super simple process
Old June 4, 2012, 01:52 PM
bissa's Avatar
why do I need to root? the reason I'm a little hesitant to do it is so I don't void warranty on my nearly brand new phone.
Old June 4, 2012, 02:21 PM
geokilla's Avatar
Don't worry about warranty. If worst comes to worst, ODIN and XDA will save the day and give you your warranty back. How? By flashing back the stock ROM.
Old June 4, 2012, 03:08 PM
almost impossible to screw up rooting a phone now and why do you want busybox installed?
Old June 4, 2012, 03:57 PM
bissa's Avatar
oh, wow, I just saw what rooting actually was. I thought it was like jailbreaking an I-phone where you have to overwrite a whole bunch of things, and might brick your phone.
I want busybox so I can create network shares of a sort on my phone, and so I can use my phone for SSH.
Old June 4, 2012, 04:14 PM
Rooting an android phone is COMPLETELY different than a iPhone and so easy to resort back to stock or whatever you want.
Old June 4, 2012, 04:32 PM
bissa's Avatar
yeah, I've heard it's easy, but all the guide I've found involved overwriting the OS. are there any guides that would work for an I9100 with ICS 4.0.3?
Old June 4, 2012, 05:09 PM
bissa's Avatar
ok, that was actually a little frightening how easy it was. I mean I could imagine someone that's completely uninformed about linux rooting their phone them killing it when they try to rm something and delete the world.
Old June 4, 2012, 06:27 PM
geokilla's Avatar
Next up! Learning custom ROMs from XDA!
Using a Panasonic bluetooth phone as a home phone chrisk iPhone & iPods 7 September 27, 2011 08:51 AM
Installing psu slaweko Power Supplies 6 February 16, 2011 07:16 AM
Installing the CPU Kieli New Builds 8 December 24, 2010 08:42 AM
installing OS Jim Guides & How-to's 6 January 29, 2009 12:52 PM
cell phone question how to transfer my cell phone pics to my comp Shadowmeph Off Topic 1 January 29, 2009 10:51 AM
