  #131 (permalink)
Old October 14, 2012, 06:54 PM
JD JD is offline
Originally Posted by Jake_HT View Post
awesome! enjoy! if you went with cm 10 they actively update it (daily) so you might wanna update every week or two.
all you have to do is download the latest nightly, boot into recovery, wipe cache and dalvik cache, install new nightly and gapps, then reboot. You won't lose anything.
Typically speaking, you shouldn't have to flash gapps every time.
  #132 (permalink)
Old October 14, 2012, 07:17 PM
Lpfan4ever's Avatar
I think it really depends on the update and what exactly was done. I'm not on CM, but an AOKP ROM for my S3. Most updates have required a gapps flash for me. But then again, I'm on AOKP.
Originally Posted by encorp
Code:
<firebane> slightly used
  #133 (permalink)
Old October 14, 2012, 08:50 PM
chrisk's Avatar
Folding Captain
I am not using CM10, but there is an updater no?
CM10 Updater, Revisited | TalkAndroid.com
Fold for team #54196
  #134 (permalink)
Old October 15, 2012, 03:33 AM
If i want to get JB on my i9000m then i just have to install the latest cm10 nightly? What about JB gapps?
  #135 (permalink)
Old October 15, 2012, 04:41 AM
JD JD is offline
I've yet to see that work on the GT-i9000M, always gives me a download error.
Just grab the latest CM10 Nightly from here: CyanogenMod Downloads and the JB Gapps here: Goo.im Downloads - Downloading gapps-jb-20120726-signed.zip
  #136 (permalink)
Old October 15, 2012, 06:47 AM
Jake_HT's Avatar
New gapps! for 4.1.2
Goo.im Downloads - Downloading gapps-jb-20121011-signed.zip
http://jakeht.deviantart.com/
  #137 (permalink)
Old October 15, 2012, 06:57 AM
Oh sweet thanks.
Btw i wanted to let you know that i skipped out the part where you asked if we wanted to use rooted apps. Can i do that any time or did i miss my oppurtunity?
  #138 (permalink)
Old October 18, 2012, 03:55 PM
Trial Member
Has anyone had success using SuperOneClick to root their I9000M 2.3.3 UGKG3?
  #139 (permalink)
Old October 18, 2012, 06:28 PM
JD JD is offline
Oh sweet thanks.
If you have CM9/CM10, it's rooted.
Otherwise, you can flash that rooted kernel (assuming your on stock ROM) anytime.
  #140 (permalink)
Old October 20, 2012, 04:08 PM
Trial Member
Default It's out there....but always noce to see someone organize it.
Phase M: Flashing Modems
Although upon flashing CM9, it will give you a modem which will likely have reception, it may not be ideally suited for our phones. From the Google Drive link in the first post, there's a folder containing my collection of modems with support for the 850MHz band which we have in Canada.
You can try them all until you find one that suits you best. Just follow the simple flashing procedure:
  1. Disconnect phone from USB (be it charging or to your PC)
  2. Reboot into recovery
  3. Install ZIP from SD card and select the appropriate modem you want to try
  4. Reboot the phone
It's key that your phone is disconnected when flashing. Some have reported a loss of signal entirely if they flash while connected. I've personally never experienced that, but better safe than sorry!
Phase R: Flash UGKG3
If everything goes wrong, or you simply want to blow away everything on your phone, continue here. I would personally recommend doing this, especially if your coming from other ROMs that may have flashed GT-i9000 bootloaders instead of GT-i9000M bootloaders. It likely isn't a big deal, but I cannot say for certain. If your phone powers up with a splash screen showing only "GT-i9000", then you have the wrong bootloader.
Power off your phone, remove external SD, disconnect USB. Hold VolDown + Home while pressing Power. It should boot to a "Downloading..." screen. Connect USB to PC. Windows should then install some drivers.
Open "Odin3 v1.85.exe" and make sure you see a COM port active (in yellow). Configure Odin to match the below screenshot. Then click Start. Sit back and relax until your phone reboots.
You should now be at a clean ROM, exactly as you'd receive the phone from Bell. I would recommend following Phase 2B at this point to gain root access and CWM.
Great forum....
I tried all the above...put me in a boot loop. Tracked down some info on how to escape the soft brick...whew. The key was holding down the power button while putting in the battery....boy....I was ready to do the not so happy dance on it....to the point of ordering another phone.
Accidently loaded CM10 Nightly and all the above. I have the bootloader from a T959 (TLJL3) inky-ghost
CWM and kernel 3.031-g35847d6. I was trying to get back to gingerbread and wow.
...I have jelly bean running on my Galaxys S GT I9000M. Found the best modem for the Vancouver area is the TIJL3. Look at your reception...not the indidcator on the top bar. Also moved away from my electronically charged office and the reception jumped immensely.
Jelly bean 4..1.2. on my Galaxy S ...mind you it thinks it's a GT-I9000.....but it's running flawlessly. Actually my phone is a shell of it's former self. ICS modem, T959 Kernel, GT I9000 bootloader... I loaded the gapps JB 20120726 and have complete access to google play. GPS is working, bluetooth, email, facelock security....everything. You wouldn't believe how hard it is not to drop a couple of "F" bombs in the appropriate places.....but you get the idea.
Thanks to this....and other forums like it...even a noob. like me. can learn enough to really screw up his phone....and love doing it.
Cheers.
"I love android so much I would kiss it.....right on the lips."
GPS on android martin_metal_88 Mobile Computing 13 April 26, 2012 07:00 PM
[FS] Provider Unlocked Galaxy S I9000M Draex Buy/Sell & Trade 5 July 30, 2011 01:47 PM
Samsung Galaxy S Froyo (Android 2.2) Update beginning to make the rounds! thorn Mobile Computing 17 December 29, 2010 10:21 PM
Samsung Galaxy with Android martin_metal_88 Off Topic 2 March 12, 2010 02:05 PM
Android muse108dc Off Topic 13 November 13, 2009 03:35 PM
