  #111 (permalink)
Old October 12, 2012, 02:38 PM
3.0charlie's Avatar
I've had enough. NCIX is giving me the run-around with my S2 (bought it a while back - phone is a UK model), and since it's still running Ginger, I want to upgrade to ICS. Kies upgrade does not work (being a UK model). They say that they can't confirm that it will work properly, and that I'd loose my phone for a week (shipping time).
So screw that. Will your procedure work for my phone? CSC is i9100XEUKD1.
  #112 (permalink)
Old October 12, 2012, 08:12 PM
JD JD is online now
Although I'm sure it would be similar steps, you definitely need different files.
I take it you have the International model? i9100? You can grab CM10 (Jellybean) here: CyanogenMod Downloads and Google Apps here: Goo.im Downloads - Downloading gapps-jb-20120726-signed.zip
Though you'll need to root your phone and install CWM on it first, so you'll have to delve through Samsung Galaxy S II I9100 - xda-developers
  #113 (permalink)
Old October 12, 2012, 08:40 PM
Jake_HT's Avatar
I don't even see a KD1 root file in this thread [07.09.2012][CF-Root 5.6] K**,LA*,LP-126BHJQ73SC89DEFWGKIQOTUX,LQ-5B - su+bb+CWM4/5 - xda-developers
You sure it's KD1??
http://jakeht.deviantart.com/
  #114 (permalink)
Old October 12, 2012, 09:10 PM
So backing up my data in kies was useless?
  #115 (permalink)
Old October 13, 2012, 07:23 AM
3.0charlie's Avatar
Thanks, I'll jump into that over the week-end.
You sure it's KD1??
Here is the phone version as it is displayed with *#1234#:
PDA: I9100ZSKF4
PHONE: I9100XXKE4
CSC: I9100XEUKD1
Build info: Jun 10 2011
Kernel info shows: 2.6.35.7-I9100ZSKF4-CL280225
  #116 (permalink)
Old October 13, 2012, 08:50 AM
Jake_HT's Avatar
PDA: I9100ZSKF4
PHONE: I9100XXKE4
CSC: I9100XEUKD1
perfect it's kf4. I'll write the steps out for you with download links when I get home in a few hours so you don't have to waste your time reading xda since it's a nightmare especially for your first time rooting. It's pretty easy! I've done 2 I9100s, 3 I9000s, my I717, and an htc sensation and the Samsung phones are very easy
  #117 (permalink)
Old October 13, 2012, 10:34 AM
Jake_HT's Avatar
Alright, this is exactly what you need to do, everything. Starting with rooting + installing CWM (clockwork mod recovery)
First, download everything: These links are for CM9 (ics) the links JD posted are for CM10. The steps are the same for either.
Odin (you will use this to flash the file to root your phone): http://forum.xda-developers.com/atta...5&d=1306787405
Root file (this is specific to your kernel 3.0 charlie, nobody else use this unless you're running KF4 kernel) CF-Root Download
Cyanogenmod9 latest nightly for galaxy s2 i9100 (4.0.4) : http://get.cm/get/jenkins/9567/cm-9-...Y-galaxys2.zip
(the stable version was released a while ago and there have been improvements since, so use the latest!) My sister has the S2 running CM9 and my GF has the S2 running CM10. CM9 works much better on the S2.
Latest Google apps for ICS: Goo.im Downloads - Downloading gapps-ics-20120429-signed.zip
Ok now you have all the files you need.
1. First thing you should do is put the CM9 nightly zip file on your phones internal SD card. I like to put everything in the "download" folder just so it's all in the same spot. Also put the gapps file in the same spot.
2. Turn off phone
3. Boot into download mode. Hold volume down, home button, and power button. When screen turns on, let go of power button but keep holding vol down and home until the download mode comes up. It shoudl say download mode/odin mode.
4. Plug your USB cable into phone/computer.
5. Check odin, in the top left it should have a yellow rectangle that shows the phone is connected. IF NOT THEN YOU MIGHT HAVE TO INSTALL samsung USB drivers if for some reason you don't already have them. Find them here SAMSUNG_USB_Driver_for_Mobile_Phones.exe
6. Unzip the root file ( CF-Root-SGS2_ZS_OZS_KF4-v4.0-CWM4.zip) , out should pop out a .tar file.
7. Click the PDA button in odin, and navigate to the CF-Root-SGS2_ZS_OZS_KF4-v4.0-CWM4.tar file.
8. Hit start. Odin will flash the new rooted kernel to your phone. It will automatically reboot.
9. Now you're rooted with CWM intalled. Time to boot into CWM to do a backup and then install cyanogenmd.
10. Boot into recovery, same as download mode but hold volume up, home, power. Let go of power when screen comes on, hold vol up and home until you are booted into recovery.
11. Use the volume keys to navigate up and down, use the power (or sometimes home) button to select.
12. MAKE A BACKUP. Incase anything goes wrong, you want a working backup. Go down to backup and make hit accept or whatever. It should take around 5 minutes.
13. Once backup is done, you're ready to install CM9. First thing to do is wipe/factory reset. This will wipe the current ROM and apps, and caches, you will still have all photos and documents.
14. Install cm-9-20121007-NIGHTLY-galaxys2.zip. You will probably have to go to choose file from internel SD card. This will take about a minute.
15. When CM9 file is installed, then install the gapps-ics file that was in the same spot you put CM9 file.
16. Reboot phone. Done. Enjoy CM9
ANY questions, let me know. I wrote this all off of memory but I've done it so many times!
  #118 (permalink)
Old October 13, 2012, 02:31 PM
JD JD is online now
I would still opt for CM10 over CM9 though 3.0charlie. Up to you. I would at least try it!
Pretty much... I never ever used Kies so I don't know if there's any way to use that data or not.
You can re-flash a stock ROM though and restore the data if you need something I guess.
  #119 (permalink)
Old October 13, 2012, 10:05 PM
If i do go back then how do i backup my contacts and stuff.
  #120 (permalink)
Old October 14, 2012, 07:13 AM
3.0charlie's Avatar
Holy crap - thanks much Jake for the complete runthrough - I'll set this up later on this evening.
So... CM9 or 10?
GPS on android martin_metal_88 Mobile Computing 13 April 26, 2012 07:00 PM
[FS] Provider Unlocked Galaxy S I9000M Draex Buy/Sell & Trade 5 July 30, 2011 01:47 PM
Samsung Galaxy S Froyo (Android 2.2) Update beginning to make the rounds! thorn Mobile Computing 17 December 29, 2010 10:21 PM
Samsung Galaxy with Android martin_metal_88 Off Topic 2 March 12, 2010 02:05 PM
Android muse108dc Off Topic 13 November 13, 2009 03:35 PM
