Old April 20, 2012, 02:05 PM
Birk's Avatar
Default Top 5 Best Android Phones?
My boss has asked me to provide him with a list of the top 5 android phones for my company to purchase as testing units for our Android department.
What do you guys suggest makes the list?
-- Main System --
THERMALTAKE Chaser MK-1
ASUS P8Z68-V Pro / Gen3
INTEL Core i5 2500K @ 4.5ghz 1.35v
- XSPC Raystorm
DIAMOND Radeon HD 6950 2gb @ 840/1325
- AQUACOMPUTER AquagrATIx Full cover Block
CORSAIR Vengeance C9 16gb (4x4) 9.9.9.24
OCZ ZX 850w Gold
WD 320gb, 1Tb, 500gb
LG 22x Super Multi DVD
Old April 20, 2012, 02:40 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Galaxy Nexus should be on there and Galaxy S3 should be out in May I think.
Old April 20, 2012, 02:51 PM
Galaxy Nexus, soon to be galaxy S III , Maybe HTC One X or XL. The One S is quite similar to the XL tho. Maybe the Moo Razr ?
Old April 20, 2012, 02:52 PM
Jake_HT's Avatar
Samsung: Galaxy nexus, galaxy note, galaxy S2(x), S3 is out soon
HTC one
Motorola Droid Razr
http://jakeht.deviantart.com/
Old April 20, 2012, 03:03 PM
I think it's best to just wait for the GS3 if it's out in the next couple of months. It will definitely be the best Android, otherwise, the Nexus is a solid device.
Old April 20, 2012, 05:00 PM
If you're looking for 5 phones for testing purposes, getting the 5 best Android phones probably isn't your best option, you want options that cover the largest possible amount of Android's install base, which almost certainly won't be the 5 best phones.
I haven't done any significant Android development, so can't give real good answers, but I suspect you'd want to get a Galaxy Nexus and a Nexus S for sure, at least one device that runs Froyo and one device that runs Gingerbread, one device with the lowest possible hardware specs you expect users to be using your app with, with as many different screen resolutions as reasonable. Probably worth getting at least one tablet too, probably a Motorola Xoom running Honeycomb depending on how well you plan on supporting Honeycomb.
Old April 20, 2012, 07:40 PM
b1lk1's Avatar
ICS (Ice Cream Sandwich) has been total garbage on most things that use it so I would not waste much time on it as it is in need of major refining before it can be considered mainstream. Gingerbread and Honeycomb are very good versions so I would suggest focusing on them.
MY HEATWARE
Old April 21, 2012, 02:43 AM
GT7R's Avatar
Galaxy II (Soon to be III) and Moto RAZR are top for me. Never liked HTC :P
Old April 21, 2012, 03:12 AM
From a business perspective I would look at the Galaxy Note and a variation of the S2 and perhaps upcoming S3 over the Galaxy Nexus as they are better fitted for business based off the size and shape of these phones.
Galaxy Nexus has a strange shape like the Nexus S
Old April 21, 2012, 05:39 AM
I disagree about the shape of the Nexus, it's actually more ergonomic than the GS2 lineup.
But, if this is from a development standpoint, you probably want the Bell GS2 (Exynos), the Rogers GS2 LTE (Qualcomm), a Galaxy Nexus for ICS, Galaxy Note and probably a Honeycomb tablet such as the Galaxy Tab 10.1.
[WTB] x2 Nexus S phones THS Buy/Sell & Trade 1 December 4, 2011 01:04 PM
Wiring Phones lcdguy Networking 5 August 24, 2011 07:26 AM
cell phones? ad5ter Mobile Computing 6 August 4, 2011 12:59 PM
Help me pick some 'phones headsh0t Audio 30 April 18, 2010 03:55 PM
cell phones? Cadence Mobile Computing 9 May 7, 2009 05:40 PM
