Old April 21, 2012, 07:57 AM
Originally Posted by b1lk1 View Post
ICS (Ice Cream Sandwich) has been total garbage on most things that use it so I would not waste much time on it as it is in need of major refining before it can be considered mainstream. Gingerbread and Honeycomb are very good versions so I would suggest focusing on them.
Really? I love ICS on my galaxy nexus.
Old April 21, 2012, 11:02 AM
chubaka's Avatar
seeing as android is so fragmented, you might want to try different versions of android on different phones..not necessarily the top 5.
Old April 21, 2012, 11:14 AM
chrisk's Avatar
Folding Captain
Galaxy Note would be ideal for business. If you want to spend your time looking at spreadsheets, documents, etc. Screen capture and annotation with the S-Pen is ideal. You can add memory, and the battery is easily replaceable, which would be something an IT dept. should consider as the batteries lose effectiveness over time, and in this case you can pop a new one in there easily. Staff who are heavy users could take an extra in their bags as well.
Fold for team #54196
Old April 23, 2012, 06:35 PM
omgwtf's Avatar
Would the GS3 be worth getting over the GS2 taking in consideration the price difference?
Memento mori
[WTB] x2 Nexus S phones THS Buy/Sell & Trade 1 December 4, 2011 02:04 PM
Wiring Phones lcdguy Networking 5 August 24, 2011 07:26 AM
cell phones? ad5ter Mobile Computing 6 August 4, 2011 12:59 PM
Help me pick some 'phones headsh0t Audio 30 April 18, 2010 03:55 PM
cell phones? Cadence Mobile Computing 9 May 7, 2009 05:40 PM
