Old March 26, 2012, 03:10 PM
Avenger212's Avatar
I checked with my local store, they said that they do not carry the Playbook or the Thrive. So yeah, but there is still the Asus Transformer and Transformer prime. What is the difference between the two they look pretty much the same to me. Also they have an Acer Iconia, is that any good? Finally they have a Samsung Galaxy. So yeah Still having trouble choosing between the four tablets. Any takers?
Old March 26, 2012, 03:25 PM
b1lk1's Avatar
Prime is one of the fastest out there right now, quad core and Tegra 3, although not much is out to take advantage of the power. Transformer, IConia and Galaxy have very similar specs and some differing features. I tend to stick to ASUS as I have brand preference there and they are very well built. I would NOT discount the other tablets in comparison so you really need to hone it down to what you really want. ASUS has the best and easiest to use dock and noone can dispute the crazy battery life when docked of the Transformers.
DAILY: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 270 2GB/128GB SSD+750GB HDD+2TB HDD
Old March 26, 2012, 10:18 PM
Avenger212's Avatar
Thank you, I'll buy the Transformer prime next week. Thank you all for your help.
Old March 27, 2012, 05:23 AM
b1lk1's Avatar
Can't see how you will be disappointed. Prime is an awesome tablet, although pricey. It has power to spare and is about as futureproof as you can get in the short term. If you are new to tablets there is a learning curve and they do not perform flawlessly like a PC does with Windows. Android is buggy but tends to cooperate for the most part. Be sure to keep backups of any and all important data.
Tags
asus , mobile computing , tablet
Cloud Computing questions Shadowmeph O/S's, Drivers & General Software 0 February 3, 2012 10:25 AM
Student buying his first tablet. Leaning towards the Thinkpad Tablet. Advice? Bentech Mobile Computing 1 November 14, 2011 09:37 AM
GPU computing/supercomputers omgwtf Press Releases & Tech News 9 March 25, 2009 08:54 PM
Distributed Computing Histories..... BrainEater HardwareCanucks F@H Team 9 September 10, 2008 02:16 PM
Distributed computing. SHaCK Suggestions & Feedback 5 February 28, 2007 12:59 PM
