Old March 22, 2012, 06:39 PM
grinder's Avatar
Did the rice bag thing on the 20th. 1 cup of long grain in a single zip-loc with the sim card tray pulled. Condensation disappeared in the camera lens this morning. Plugged it in 12 hours later and it fired up like a champ!
thanks all!!
Old March 23, 2012, 04:12 PM
BrainEater's Avatar
I almost missed this.
Rob : HAAAA haaa
Supermicro X11DPi-NT:2x Xeon Gold 6144's:Lots more other stuff.Dual 4k monitor video .
Old March 23, 2012, 07:24 PM
ZZLEE's Avatar
bag off rice / win
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old March 23, 2012, 08:01 PM
BlueByte's Avatar
The bag of rice works...what it does not seem to do is fix the long term damage. My wife`s phone was dropped in the tub with a photo/baby mishap, did the bag-o-rice trick for a few days worked like a charm.... except 6 months later her signal is 20db worse then mine in the exact same spot.... that's enough to make her phone almost unusable in many areas around us. I was thinking of trying to clean the antenna up from what I assume(hope) is only some sort of corrosion.
Old March 23, 2012, 08:37 PM
ZZLEE's Avatar
Best results on bag of rice is a week or two weeks. then in oven at 105 f ( 40 c ) fore a couple of hours.
Pray to dieity. ...
Old March 23, 2012, 08:48 PM
NyteOwl's Avatar
this will sound counter intuitive but ...
0) preheat regular oven to 100F
1) remove battery
2) rinse phone under cool clear water (distilled if possible), and as soon after being dunked or spilled on as possible - try not to elt dry before rinsing
3) same for battery.
4) turn oven off
5) carefully dry battery off and let air dry
6) dry phone as thoroughly as possible with dry cloth
7) place phone on a paper towel in the oven until most of heat has gone from oven
8) place phone in ziplock with rice overnight
That should clean out and eliminate all the moisture and if you can rinse with clear pure water, mitigate most if not all of any long term damage.
We've used this procedure with phones and two-way radios used in the field for years and it works 100% most of the time. Only occasionally, if moisture gets trapped in a tight sport or the liquid was corrosive was there later problems.
Obsolescence is just a lack of imagination.
Old March 24, 2012, 04:36 PM
grinder's Avatar
i would like to crack the phone to be thurough... looks like i need a funky security bit tho
Old March 25, 2012, 02:47 PM
BrainEater's Avatar
I have every security bit made.
I'll bring em thurs.
  #19 (permalink)
Old March 25, 2012, 05:06 PM
Perineum's Avatar
Quote of the year:
I dropped my Cpu on the floor, it`s fine?? deiu99 CPU's and Motherboards 5 November 22, 2011 02:18 PM
Using a Panasonic bluetooth phone as a home phone chrisk iPhone & iPods 7 September 27, 2011 08:51 AM
PPD Dropped drastically? Slaughter HardwareCanucks F@H Team 19 June 14, 2011 07:55 PM
Oracle to buy Sun for $7.4B after IBM dropped bid 3 of 7 O/S's, Drivers & General Software 1 April 21, 2009 08:52 AM
cell phone question how to transfer my cell phone pics to my comp Shadowmeph Off Topic 1 January 29, 2009 11:51 AM
