What ever model you end up choosing, make sure you go with Chapters/Indigo (Kobo) since they have WAY more ebook in Canada then Amazon does. Since Chapters/Indigo is a Canadian company they have more publishing rights for ebooks in Canada then Amazon does. Amazon.com has more ebooks than Amazon.ca as a result. So, if you want to go Kobo and you are thinking of getting the Vox (which I have) for $200 then I would recommend you get a BB Playbook (which I also have) for $200 and use the Kobo app instead (which is included) since the Playbook hardware is far superior to the Vox. Or just get the regular touch e-ink version which is pretty good (I also have the non-touch e-ink version which is pretty good). Also, with the Kindle you are limited on what services are available, the video and music downloads don't work in Canada and the App store also doesn't work in Canada.
__________________ GAMER: Win7 Pro x64, I7 3770 (stock) (CM 212+), Asus P8Z77-V Pro, XFX 6950 2GB, Corsair Vengeance LP 4 x 4GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Intel X25-M 160GB, 1TB WD Blk, DVD, BRD, HX750W, Auz X-Fi Prelude, Intel Pro CT Gbit NIC & CM Cosmos Game Server: Win7 Pro x64, AMD Phenom II X4 960T Zosma, Gigabyte GA-MA770-UD3, 4x2GB Gskill DDRII 1000, 640GB WD Blk, 1 ODD, Asus 9600 GSO, Intel Pro PT Gbit, Corsair 400W PS & Antec 300. |
