Old October 18, 2011, 01:26 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Originally Posted by Soultribunal View Post
Hmmmm, Core Temp / Real Temp, Afterburner all default to Celsius for me. And that is how I have always read them :)
I stand corrected. Long day for me.....
Old October 18, 2011, 01:29 PM
Was gonna say it's all in Celcius for me. Thanks ST. So basically I don't want both temps, just Celcius in the pics.
Old October 18, 2011, 08:23 PM
having now owned every alienware model since dell took over I can tell you that the m14x is really not worth the money. You would be much much better off getting an older m15x. build quality is much better and the system is upgradeable (which is the main reason to buy alienware) the lack of an mxm card on this notebook makes it and all around fail at its price point.
I7 920/TRUE 120E/6gb Corsair ddr3 1600 dominator/Rapage II Extreme/sapphire 4870x2/2x WD 500gb AAKS/Antec Sig 850w/Lian Li PC7
I7 920/TRUE 120E/6gb Corsair ddr3 1600 dominator/Gigabyte EX58-UD5/2x ATI 4850/Samsung 1TB f1/Corsair HX620/Lian Li A05B
Q6600ES/OCZ Vendetta 2/4gb Mushkin ddr2 1000/Maximus Formula/ATI 4850/WD 500gb AAKS/Antec Sig 650w/Antec p150
Q9300/Zalman 9500/4gb buffalo firestix/P5Q delxue/Asus 8800gs/WD 1tb Green/Antec Neo HE 550w/Lian Li 6070b
I need more than 500 Characters
Old October 18, 2011, 09:09 PM
I was gonna say Just Cause 2 was the only game I really liked on that list lol
Very nice review, I own one of these and I'm extremely happy with it. Just wish it wasn't so loud, it could obviously stand to have a different fan speed profile and slightly higher temps. And forget about overclocking the GPU
Old October 19, 2011, 02:00 AM
Galcobar's Avatar
Originally Posted by SKYMTL View Post
The images get VERY cluttered when using both.
Plus, how many times have you heard of component temperatures being measured in Celsius?
I see Celcius in the review's graph of component temperatures, directly above the photos in question -- courtesy of HWInfo and GPU-Z.
Old October 19, 2011, 05:24 AM
Neolithium_Wpg's Avatar
That keyboard looks way better than my G73. Plus this Asus trackpad makes me want to vaporize small furry animals, so I can't believe I'm saying this but I may want to look into one of their gaming notebooks. That fan noise is unfortunately a pretty big negative for the notebook as a whole though...
Dell XPS8700 | Asus x101ch | iPhone 5 (iOS7)
A Veteran, whether Regular Force, Reserve or Retired- is someone who, at one point in their life, wrote a blank cheque made payable to the Dominion of Canada for an amount of "Up to and including my life"
-Author Unknown
Old October 19, 2011, 05:26 AM
SKYMTL's Avatar
I beg to differ.
The M15x has an extensive cooling system which can take the additional heat load from higher end MXM cards. The M14x doesn't.
I should also note that only higher-end mobile GPUs are regularly available in MXM form factor while the smaller cores are usually integrated onto a notebook's primary or secondary PCB.
Finally, with sources for MXM cards quickly drying up, the few which are still available will generally cost so much that you're almost better off buying a new notebook.
See above. 'Twas a looooong day yesterday and I made an idiotic post.
Old October 19, 2011, 08:47 AM
MXM cards are not really drying up, they only carry so much stock on one type of card. There is nothing saying that when the amd 7 series cards come out there will not be a new supply. Also it's a huge advantage when your warranty runs out on a gaming system because the video card is normally the first to go. Also right now I am selling a 6990m for $450 and I have seen 6970m go for $350. Its a lot but when you consider you will be getting 2x, if not more gaming preformance than the 555 its really is worth it. The differnce between trying to sell off your old m15x and buy a new m14x will be greater than just spending $350 to upgrade your video card.
The m11x is a nice laptop even though the graphics preformance is lacking. Its size means that it is 100% portable which is a major plus. The m14x is already a clunky laptop which is going to need its own bag, in which case you might as well add 2lbs and bring a m15x or any of the other 15" mxm laptops.
  #19 (permalink)
Old October 27, 2011, 01:08 PM
is it a good choice for home recording studio
  #20 (permalink)
Old October 27, 2011, 01:51 PM
SKYMTL's Avatar
I don't see why not....
ASUS G74SX-A1 Gaming Notebook Review Comment Thread SKYMTL Mobile Computing 22 February 3, 2012 11:27 AM
ASUS U36SD-A1 Notebook Review Comment Thread SKYMTL Mobile Computing 19 October 30, 2011 10:04 PM
Samsung Series 9 Notebook Review Comment Thread SKYMTL Mobile Computing 9 September 2, 2011 12:41 PM
Alienware TactX Laser Gaming Mouse Review Comment Thread SKYMTL Peripherals 18 October 6, 2010 04:14 PM
