Old September 17, 2011, 07:07 AM
b1lk1's Avatar
Default HD 1080p playback on a netbook
OK, if you read my other thread, first you need to buy this:
Broadcom.com - Featured Product - Crystal HD Solution
They can be found on Ebay for roughly $50 + shipping depending on how fast you want it. I can recommend a seller if you need as I bought mine there.
Next, you need this:
CCCP - Combined Community Codec Pack
This will give you the codecs needed to play any media file and the media player that is included, Media Player Classic, works with the HD Decoder and VOILA! HD video on any netbook.
Make sure you open up your netbook and see if there is a PCIE slot before buying anything. You most likely will need to remove the WLAN card to do this, but that is of little consequence considering you'll most likely be near wired internet at home anyways. Great way to turn almost any netbook into a HTPC instead of a paperweight.
MY HEATWARE
Old September 19, 2011, 07:39 PM
b1lk1's Avatar
For the record, my netbook does a better job playing HD video than my laptop which has a G210M video card so this thing really pays for itself.
MY HEATWARE
DVD9 playback and how to convert into mkv? Arinoth HTPC Systems & Software 3 October 17, 2010 01:53 PM
Blueray Playback, it seems complicated. superj HTPC Systems & Software 9 January 3, 2010 09:09 PM
1080p out on laptop/netbook not for gaming. kyle_L Mobile Computing 8 August 17, 2009 01:32 PM
question about video playback Generic User #2 O/S's, Drivers & General Software 11 April 27, 2009 02:13 PM
