-   Mobile Computing (http://www.hardwarecanucks.com/forum/mobile-computing/)
-   -   Laptop Cooler (http://www.hardwarecanucks.com/forum/mobile-computing/45655-laptop-cooler.html)
Sevada August 15, 2011 12:47 AM
Laptop Cooler
Hi guys, as the title says, I am looking for a decent laptop cooler, for a 17" laptop. Not too pricey and with decent performance. I thought cooler master had some good ones...what do you think?
supaflyx3 August 15, 2011 01:11 AM
From what i've seen, laptop coolers just make things worse, although this was from a couple years ago so it may be different now, you may just be better off having a book or something under the bottom feet.
Sevada August 15, 2011 04:11 AM
I tried putting something under it so it's not touching the table but it still gets hot...
neojjjk August 18, 2011 09:22 AM
in my opinion laptop cooler will reduce the temp .I had a dell inspiron 15r with i3..it was turning off when writing dvds .the reason was overheat.then I bought a laptop cooler(coolermaster infinity).it reduced the temp ,and I solved the old issue .
set the fan in medium settings ,then buy a ac to usb charger .
