Old August 11, 2011, 09:14 PM
Default Comp. Sci. Laptop
I will be attending university in September, going into computer science and hoping to specialize in game development. I'll need a new laptop with decent battery life for classes, and no more than 15.6" in size. Playing games isn't very important since I have a desktop, but I'm not sure what kind of performance is needed for game development and programming. I would also like to keep it as low-budget as possible (under $1000 for sure). Any suggestions?
Old August 11, 2011, 09:31 PM
supaflyx3's Avatar
I don't know any laptops off the top of my head, but try and find something with a nvidia quadro GPU to help with CAD and such if you're planning on doing game development
Old August 11, 2011, 10:54 PM
ZZLEE's Avatar
Eurocom are cofigurable if you can find a used one even you can likely fix it up. :)
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
putting together my first comp john90009 New Builds 24 July 18, 2011 09:15 PM
What CPU is in a IBM per comp 730 - P75 ZZLEE Troubleshooting 6 December 28, 2010 07:18 PM
New Comp BigB New Builds 12 September 15, 2010 07:35 AM
new comp djnocide CPU's and Motherboards 1 March 21, 2008 07:34 PM
My Comp... acolite Case Mods, Worklog & Gallery 3 November 10, 2007 09:31 PM
