-   Mobile Computing (http://www.hardwarecanucks.com/forum/mobile-computing/)
-   -   iPhone 4 help? (http://www.hardwarecanucks.com/forum/mobile-computing/45031-iphone-4-help.html)
Beastylemon July 19, 2011 06:29 PM
iPhone 4 help?
I have an iphone 4 originally with telus.
When i restore it, i have to insert a sim for the phone to be unlocked right?
So is it possible to put in a rogers sim card? and then the phone to be unlocked to rogers?
supaflyx3 July 19, 2011 06:31 PM
yes that'll work just fine.
supaflyx3 July 19, 2011 06:32 PM
Just keep in mind that if you're in an area that rogers doesn't have 3G, you won't have any service at all since telus doesn't have an EDGE network.
Beastylemon July 19, 2011 06:32 PM
so it will now be locked with rogers, and i cant put my telus sim in there unless i restore and unlock it with the telus sim card right?
Beastylemon July 19, 2011 06:33 PM
basically my main question is "is it possible to turn a telus iphone into a rogers iphone"
Infiniti July 19, 2011 06:40 PM
No it's not possible. Restore only restores the original firmware that your carrier has for it, hence it'll be locked.
The phones you get from Apple to be replaced have special firmware that locks it to whatever SIM is inserted first.
Beastylemon July 19, 2011 06:41 PM
So wouldn't a carrier switch work if i restore to a firmware i downloaded?
Infiniti July 19, 2011 06:43 PM
I'm actually not too sure if you can download that firmware, but I'm going to assume no.
supaflyx3 July 19, 2011 08:08 PM
You have to jailbreak and unlock it first.
Beastylemon July 19, 2011 08:36 PM
if you take it to rogers, can they change it for you?
