Old May 12, 2011, 11:51 AM
Default Thoughts on this budget gaming laptop?
I'm getting my wife a laptop that she can do moderate gaming on (Jewel Quest, Sims 3 - that kind of thing)
Budget in the $500-$600 range.
I found this one on NCIX which looks like it'll do the job just fine, but I figured I'd check with the hive-mind here before hitting the "go" button.
NCIX.com - Buy Acer Aspire AS5552G-7464 AMD Phenom II X4 N970 6GB 500GB 15.6IN Radeon 6650 DVDRW WIN7 HP Notebook - Others - LX.RC402.067 - in Canada
Main concerns are:
Wireless capability - the Inspiron 1521 we have now drops connection CONSTANTLY. We'd like to stay connected to the net for more than 5 minutes at a time.
Moderate level gaming - as mentioned, Sims 3 is probably the most demanding game it'd play.
I know it only has a 5400rpm hard drive but I'm not overly worried about that - can always replace with a SSD down the road if needed.
Thoughts on this one or recommendations on other laptops (cheaper ones that would still do the job) are appreciated.
Thanks!
Old May 13, 2011, 07:20 AM
cpu is not so good .try to get an i3 / i5 based laptop for more battery life.
Old May 13, 2011, 09:46 AM
if she's not looking for something mobile i would say the labtop you've got is pretty solid for the budget. im not an expert but the 6650 is the best your going to do at that budget. i dont think the cpu will be the bottleneck unless as the poster above mentioned you want batt life
you might get away with something like this Acer Aspire 5742-6692 w/ Core i3-380M, 6GB, 500GB, DVD+/-RW, 15.6in HD, Win 7 Home Premium 64-bit at Memory Express Computers Asus K42F-B1 w/ Core i3-370M, 4GB, 500GB, DVD+/-RW, 14in HD, Win 7 Home Premium 64-bit at Memory Express Computersbut the gaming graphics wont be on par with the mobile 6650
Old May 16, 2011, 10:05 AM
Thanks for the feedback guys.
Laptop will mostly be plugged in, so I'm not overly concerned with battery life.
$2500'ish (broken budget already, 3K now) Gaming Build - Suggestions/Thoughts? Caldezar New Builds 57 August 15, 2010 03:23 PM
"budget" gaming laptop b1lk1 Mobile Computing 16 February 14, 2010 09:08 PM
Your thoughts on this laptop? canmx120 Mobile Computing 10 January 6, 2010 10:40 AM
Any and all thoughts welcome.. ( gaming build ) phatchantz New Builds 0 October 10, 2008 04:02 PM
Thoughts on a build? $1200 budget zlojack CPU's and Motherboards 17 March 26, 2008 06:56 AM
