-   Mobile Computing (http://www.hardwarecanucks.com/forum/mobile-computing/)
-   -   Need to buy a laptop (http://www.hardwarecanucks.com/forum/mobile-computing/4126-need-buy-laptop.html)
v0maru January 17, 2008 11:56 AM
Ok so im looking for a laptop under $900 dollars CAD, that's my budget
And i want one that's not so hot, good battery life
And hopefully it can play 3dgames + playing music and searching internet at the same time
is this possible?
don't care what brand
Cptn Vortex January 17, 2008 02:02 PM
What size? ASUSTeK F9Dc-A1 Notebook at FrontierPC.com Canada
v0maru January 17, 2008 02:52 PM
Size 15.4" or less 17 is too big, for some reason 13.3 " is more expensive then 14 and 15s right?
Mr. Friendly January 17, 2008 05:38 PM
is this possible?
the Acer 5790-6279 probably will suit your needs:
http://www.ncix.com/products/index.p...nufacture=Acer
it can be price matched for about $880 from Infonec.com.
DaBruuzer January 17, 2008 06:06 PM
As much as I dislike Futureshop, for a 15.4" this one is a good deal:
Future Shop: Computers: Laptops: Toshiba Satellite Intel Core2 Duo T5250 1.5GHz Laptop (A200-TJ6) - Future Shop Exclusive
For a 14.1":
Future Shop: Computers: Laptops: HP Pavilion Intel Dual Core T2330 1.6GHz Laptop (DV2714CA) - Future Shop Exclusive
Mr. Friendly January 17, 2008 07:08 PM
alas Bruuzer, only the Toshiba w/HD2400 has a chance with any games, and it doesn't have a chance with any games, which is what the OP is hoping for. it's a tall order for something $900ish, but the Acer 5720G I mentioned fits perfectly.
DaBruuzer January 17, 2008 08:25 PM
Ah, you are correct - missed the part about 3D gaming. I am not sure I could recommend gaming on either of those.
Supergrover January 19, 2008 10:59 AM
I'll second this lappy,for under 9 bills its a solid little unit. Although the touch pad is a little sensitive IMO, but that could just be me, I hate touchpads
