Old September 30, 2010, 01:04 AM
FlyingFish's Avatar
Default The thing that you put where the DVD drive goes
Apologies for the lousy topic title. I couldn't think of a better one.
I have an ASUS UL80 and I want to remove the DVD drive. That part is easy. The hard part is finding a little plastic thing to put in there so crap doesn't get in the drive slot. I know some laptops come with them.
The problem is I can't seem to find one online, and I can't really think of what it would be called.
Any suggestions would be appreciated :-)
Old September 30, 2010, 10:10 AM
CroSsFiRe2009's Avatar
I'm going to take a wild guess that you installed a drive in the bay using an adapter? Short of buying a used slim drive, stripping it apart and remove the dvd drive guts and reusing the old bay cover I can't think of any way. A better option would be to pick up a hard drive caddy from ebay for $30 and install a drive that way. The Lenovo slim caddies work as far as I know. The opening will be covered but I'm not sure if you can attach the old dvd drive faceplate back on
If you aren't actually putting in a second drive...I have no idea sorry.
Old September 30, 2010, 03:57 PM
FlyingFish's Avatar
Yeah I don't really need to add a second drive, I just want to remove weight. I recall that some older laptops used to come with a placeholder. I might just pickup a caddy because it would be lighter than the DVD drive.
Old September 30, 2010, 04:03 PM
I wasn't aware DVD drives weighed that much O.o
Old September 30, 2010, 07:58 PM
Thats a really stupid idea just to save some weight, the dvd drive doesnt weight that much, if anything I'd take a guess and say the hard drive weighs about the same, get an ssd and strip off the casing if you really care about the weight and while your at it, just remove the steel reinforcements underneath your keyboard, they're hardly needed, take out the reinforcement plate for the dvd drive -.-. Seriously, you wont notice the weight you save. I got the UL50VT cracked out on my desk at the moment and in no way does the dvd drive make up a significant portion of the weight of the laptop in total.
Old September 30, 2010, 09:11 PM
FlyingFish's Avatar
Well thanks for the help everyone.
how do I open my dvd drive? hen555 Guides & How-to's 3 April 30, 2010 06:52 PM
A Good DVD-DL drive? ImmaPC Storage 20 October 14, 2009 06:16 AM
[WTB] Working DVD Drive jcmaz Buy/Sell & Trade 1 October 13, 2009 07:56 PM
dvd drive on its side. kyle_L Storage 2 May 31, 2009 05:13 PM
[WTB] White DVD/RW Drive Sniper Buy/Sell & Trade 6 December 28, 2008 10:29 PM
