-   Mobile Computing (http://www.hardwarecanucks.com/forum/mobile-computing/)
-   -   screen res controlled by actual screen or laptop (http://www.hardwarecanucks.com/forum/mobile-computing/34668-screen-res-controlled-actual-screen-laptop.html)
supaflyx3 July 29, 2010 03:46 PM
Hey, i want to upgrade a laptop screen from 1366x768 to 1920x1080 because i really hate scrolling so much.
I was wondering if the res is restricted by the actual panel or the video card/motherboard thanks.
ZZLEE July 29, 2010 04:10 PM
what is the actual pixal size of the screen ?
What vidio card in the lap top ?
What lap top is it ?
Generly yes you can Control pannel/ (display) / resulution (play with it ) / should give you 30 seconds to say yes or no . :biggrin:
Zero82z July 29, 2010 04:32 PM
The panel is what limits the resolution. It only has so many physical pixels.
supaflyx3 July 29, 2010 08:36 PM
Well, i should have done my research before even asking this. Can't even buy panels larger then the OEM panel (dell 1525) lame :\
