Old April 18, 2010, 10:36 PM
Default High Laptop Temperatures?
Hi,
I have a Dell Studio 15 Laptop with 2.16 Ghz Core 2 Duo processor, ATI Mobility Radeon HD 3400 series.
Whenever I play games like UT2004, temperatures of the processor and graphics card shoot up to ~80C.
Idle, the temps are ~40-45C. The ambient temperature is around 30C.
Are these normal temperatures for a laptop? If not, how can I cool it down practically?
Thanks in advance.
Old April 18, 2010, 10:44 PM
Laptop temps are always higher than reg PCs. Get one of these or something similar. I have this model and temps went down 8 to 10.
Zalman ZM-NC2000B Notebook Cooler Black Aluminum Dual Fan 1100-1500RPM USB - DirectCanada
"What is the colour when black is burnt ?" - Neil Young
Old April 18, 2010, 10:48 PM
Those are pretty normal temperatures for a laptop while under load. Laptop CPUs do heat up quite a bit, but they are designed for it and it's not a problem.
Old April 18, 2010, 10:51 PM
Thanks for a replies! I'm a bit relieved now. I'll try getting one of those Laptop coolers....
Old April 18, 2010, 10:54 PM
burebista's Avatar
You can try to lower VID and keep your CPU stable. ThrottleStop is a very handy tool for that.
If it ain't broke... fix it until it is.
Old April 19, 2010, 10:50 AM
clone63's Avatar
As others have said, those temps are pretty normal. A laptop cooler might help a few degrees, and there is undervolting, which it sounds like that's what ThrottleStop is supposed to do, but my CPU wasn't supported. The "Undervolting" Guide That is a great guide for undervolting Intel platforms.
Old April 19, 2010, 11:02 AM
Thund3rball's Avatar
This might be obvious but also make sure not to block vents or grills. Like if you're using it in bed a blanket can easily bunch up and cover an exhaust hole. And be careful with actually using a laptop on your lap... I know someone who actually got a burn on their leg from one.
"this is not troll. this is real deal!" - hohohee
Desktop:
See the drop down!
Laptop: Dell XPS M1530 \\ T7500 2.2GHz \\ 3GB 667 \\ 6 Cell \\ 8600M GT \\ 200GB 7.2K \\ WSXGA+ \\ Bluetooth/Wireless \\ MS Blue Track Mini \\ Vista Ult. (RED)
HEATWARE
Old April 20, 2010, 06:22 AM
Thanks a lot burebista and clone63! After following that great guide, I managed to get the temps to drop from ~85C to ~65C under load!
@Thund3rball: Thanks for the tip.
Old April 25, 2010, 06:45 PM
Hmph, voltage was unstable, so I have to bump voltages up a bit...
Ran folding for ~24 hours straight...
What should be the ideal temps? I'm now getting ~75C. Is this okay for prolonged periods of time? Or do I have to find some way to decrease it?
Old April 25, 2010, 07:13 PM
75C is fine.
Overclocking + Temperatures rocklobster Overclocking, Tweaking and Benchmarking 11 March 19, 2010 11:14 PM
Are these temperatures ok? what can I do to lower them? mtrpcic Overclocking, Tweaking and Benchmarking 3 October 19, 2009 11:53 AM
Are these temperatures ok? what can I do to lower them? mtrpcic Overclocking, Tweaking and Benchmarking 0 October 19, 2009 10:38 AM
[FS] BNIB High End Radiator 240 TFC **High Performance** qaz393 Buy/Sell & Trade 4 August 17, 2009 01:47 PM
What temperatures are your HDD? Silvgearx Storage 10 January 31, 2009 04:33 PM
