Originally Posted by miggs78 Yukon that's a nice laptop no doubt, but why that when you get a Dell with an i3 quad processor for about the same price? |
Well, there is no such thing as an i3 quad-core processor. Perhaps you meant dual-core? The i3 and i5 mobile processors are dual-core (i5 features Turbo boost while i3 does not). The only quad-core for mobile use from the Core family is the i7 mobile.
At any rate, the main reason I didn't go for an i3, i5, or i7 mobile is that I don't need the power they provide and the ULV (ultra-low voltage) models aren't available at this time. The Core2Duo ULV's processors are plenty powerful for what I need (school, web, multimedia).
After looking past specifications, I started to research what would really matter for me, which is the user experience the laptop provides. Firstly, I wanted something thin and light that was easily portable for school. The U450P, part of Lenovo's thin-and-light line of notebooks, provides that for me. The Dell Inspiron 14 and Studio 14, while both under 5lbs, are both a bit bulkier than the Lenovo. Secondly, I wanted a good keyboard and touchpad. The U450P once again shines in this area. The keyboard quality is what you'd expect from a Lenovo notebook: tactile with minimal flex and good key travel. The touchpad is large, supports gestures, has a great scroll feature, and sports two separate buttons. Finally, I wanted solid build quality and a good design with minimal gloss finish to keep fingerprints from molesting my laptop. The U450P is sturdy and you can tell that it is well built all-round. The design is very classy with a textured diamond pattern that doesn't attract fingerprints. Dell's Midnight Black color option is a glossy fingerprint magnet, and while you can choose other less glossy finishes, the options are slim, unless you go for the Studio and pick a design. Hot pink or lime green? No thanks.
To sum it up, Lenovo's notebook quality is generally higher than the competition and the U450P fitted my needs perfectly. The Sony VAIO lineup is nice, but I didn't want to pay $2000 for a brand name.
