Old February 24, 2010, 02:21 PM
Beastylemon's Avatar
Default Gateway FX GPU Fan 'Pulsing'
Yea.. at 45 degrees C, the GPU fan pulses and its ANNOYING THE *&^$ out of me..
The fan turns on, then turns off every second. And when its not blowing, there is a very feint high pitched noise,,.. Its a 9800m 1gb gts.. any help?
Old February 24, 2010, 02:56 PM
gingerbee's Avatar
you can just set it too one speed adn be done with it
rivatuner RivaTuner
How to clean phoenix gpu fan effectively? 0o0 Video Cards 13 January 16, 2010 05:45 PM
[FS] Gateway FX Gaming Laptop Table21 Buy/Sell & Trade 3 August 25, 2009 05:43 PM
Gateway XHD3000 belgolas Display Units 3 March 16, 2009 07:56 PM
Gateway P-7811 FX Natamanchuk Mobile Computing 9 October 3, 2008 02:31 PM
