Old January 24, 2010, 06:15 AM
Rison's Avatar
Default Matte screen laptop
A friend of mine asked me to recommend a laptop for his side business. The short story is, he installs pools and will be in his vehicle / out in the sun (etc) and needs something with a matte screen, or anti-glare.
I have done a few quick searches on ncix and found a few on dell, but wondering if you guys would recommend another brand, local to canada for under $1000. Even though he's asking for something specific, he sees the cheap laptops at Futureshop and thinks he can get one with a matte screen for $600..
Needed specs:
- 13"-15" matte screen
- Intel dual-core 2.0Ghz+
- Min 3Gb ram (not huge, can upgrade typically)
- needs dvd burner
- Relatively thin/light (once again, asking for the world)
Thanks
I'll learn to manage my anger, when people learn to manage their stupid.
Old January 26, 2010, 06:08 AM
lcdguy's Avatar
if he wants thin and light under a grand then he should be looking at asus or a netbook. But those usually don't come with matte screens. If he can increase his budget he should take a look at what lenovo is offering.
Old January 29, 2010, 12:26 PM
If it's just a work laptop, I personally would buy the cheapest used Dell Latitude with a matte screen I could find than spend $600 on something new. (It shouldn't cost more than $200 for an old D510) If he's looking at spending $600 on a laptop, money is obviously an issue and he'd be better off getting something older and hopefully well made, because it will eventually be sat on, dropped or stolen if it lives in a vehicle much of the time. A $200 laptop cracking under a fat ass is a lot better than a $600 laptop cracking under a fat ass.
Needed specs:
- needs dvd burner
Thanks
Old February 8, 2010, 01:10 PM
lcdguy's Avatar
i would also check out the Lenovo X100e. It's apretty sweet little unit. Been playing with one at work. It's like a netbook on steroids.
Old February 8, 2010, 05:47 PM
Sushi Warrior's Avatar
Dell Latitude or a Lenovo, they almost always have matte screens and are pretty cheap.
Anyway to use a laptop screen as a second monitor? BobbyLou Mobile Computing 4 December 31, 2009 12:32 PM
[WTB] Laptop w/17" screen 3.0charlie Buy/Sell & Trade 1 September 27, 2009 02:48 PM
Need Help. Re: Replacement Laptop Screen SKYMTL Mobile Computing 10 September 10, 2009 04:30 AM
MAC DDR laptop mem in an Intel based laptop? sswilson RAM 6 June 2, 2009 12:30 PM
Laptop / Laptop build T.t74)Rocky New Builds 0 November 8, 2008 08:29 AM
