Old January 15, 2010, 04:20 PM
Finch's Avatar
Default URGENT Old laptop upgrade question
hi all,
usually i do not need help regarding pc's but for laptops i am newb here. so i just have a quick question. i have a dell latitude cpx here that i cannot find the exact model number but it has a ibm travelstar 20gb hdd in it and i would like to upgrade it. i dont know what is compatible with it. i know it is a ide 2.5'' but i dont know what would be the max size supported. can i put something like 80gb, 160gb? it would be running windows xp. if you guys have links of products it would be appreciated.
also it has a p3 650mhz that looks to be on a mmc-2 socket and i found a 750mhz on ebay that is on the same socket aswell. would it be compatible?
i need a quick answer because ebay auctions ends quick
thx in advance
I5 750 2.6ghz @ 4ghz 24/7 - EVGA P55 FTW - G-skill Ripjaws pc3-16000 8gb @ 2000mhz - 2x HD5870 - Azentech Prelude - Raid 0 640gb for Main OS - Corsair TX850w - Watercooling
If you are an overclocker please come and participate to the HWC Benchmarks Competitions, look for the stickies.
Old January 15, 2010, 05:54 PM
b1lk1's Avatar
Changing to a 750MHz CPU will offer almost no gain at all in speed, waste of cash. Instead of changing the drive I would get an external USB drive to store all data and just use the 20GB drive for the OS install. It's very likely that chipset/BIOS will not support over 37GB anyways.
MY HEATWARE
Old January 15, 2010, 06:00 PM
Finch's Avatar
thx for you're reply. i know it is a "waste of cash" but it is a customer that wants me to upgrade the laptop and he has a budget allowed for this. For 30$ i think it is worth it especially that this laptop is slow with windows xp. the laptop already has 512mb of memory wich i think is the maximum allowed so the only think remaining to skeeze a little more performance is the cpu and hdd.
so you think this chipset allows only 37gb maximum so maybe i could at least put a 40gb hdd then. How can i know the maximum size the chipset will support?
Old January 15, 2010, 06:03 PM
b1lk1's Avatar
Can you find the exact model number?
As for the CPU, it should be supported but it is honestly a crapshoot. Look on Dell's site for any BIOS upgrades first.
MY HEATWARE
Old January 15, 2010, 06:05 PM
MarkOne's Avatar
My old P IV laptop is slow like Hell, I have 512 gb and a fresh install of Xp with everything fancy disable.. customer always expect miracle. just told him it will not happen with a PIII
Old January 15, 2010, 06:11 PM
Finch's Avatar
the only thing i can see is dell latitude cpx ppx
yes but i already told that to the customer IMO it is not worth 5cents but meh i dont take the decisions
Old January 15, 2010, 06:43 PM
MarkOne's Avatar
Believe me, you not out of trouble if you do everything customer ask.
Old January 15, 2010, 06:53 PM
b1lk1's Avatar
Have to agree with Markone here, this customer will be even more upset when the machine is no faster and money was spent. Getting a USB external drive is also smarter since it can transfer to the new laptop the customer really needs. This is a no win for you as the technician, I would personally refuse the work as would 99% of most shops when it comes to attempted upgrades on obsolete machines.
MY HEATWARE
Old April 21, 2011, 08:03 PM
Trial Member
Exclamation Old is New
I was told a Latitude Dell LS would not support a large drive, there are PATA drives at the 320GB level or similar, over 250GB anyway, XP will see that, Win 9x (95-98-ME) will not. However, you can get a format of 120GBs from a larger drive, Formatting with Windows 9x allows an easy swap, with Vista or XP, the chipset and variables must match, then it assumes the same system with new peripherals. Trust me, I work on these for a few years now, just look on YouTube to see what can be done.
The C series includes the CPx all the way to the C800s and above, C800 series has Pentium 3 Tualatin and built in DVD/CD drives as well as modules, the CPx and C600, C610, and C640 share the same outward hardware so motherboards can be swapped, even among Inspiron with the same specs. I took them apart and shared things like 14.1 inch displays among the 600-640s, where the CPx and CPt, etc, tend to vary is the evolution to Pentium 3, and Dell supported three speeds there all in all I believe, 650, 750, and 850 PIII Coppermines
For the MMC-1, perhaps same appearance as the PIII machines but the hardware WAS revised as far as layout. The only real problem is USB x1 port and Dell's reluctance to move to 2.0 USB for some time, and these demand often to have a USB support card and no Internal Ethernet is the main drawback, no miniPCI card for Wifi onboard, so try a port replicator perhaps? Some allow additional features, as well as a power source if the jack goes bad on the main laptop.
To also note, two front modules for the Latitudes means you can buy two batteries and use them in both slots! My first computer was a 700Mhz Celeron, and it came with DVD combi drive, so the speed of the CPU is really no issue. Tualatin is the best, but Coppermine is no slouch! Mobiles are faster then desktops I believe
Old June 2, 2011, 04:00 AM
Best upgrade for such an old laptop would be a SSD, there is one on newegg, 8GB, ATA, but is 100$, more than that laptop costs right now. Otherwise, I would consider giving it up completely such an old configuration .
Upgrade Question boing CPU's and Motherboards 1 August 16, 2009 07:20 PM
Upgrade Laptop CPU??? jcmaz CPU's and Motherboards 10 July 14, 2009 07:32 AM
Acer laptop noob, question(s) Cowinacape Mobile Computing 23 November 26, 2008 11:19 PM
WTB: Laptop Notebook 2.5" Hard Drive SATA 160gb or higher *URGENT* Jamz Buy/Sell & Trade 2 November 19, 2008 06:56 AM
Another question about acer from a laptop nOOb Tazer-[X] Mobile Computing 1 November 4, 2008 04:20 AM
