Any Sata 2.5 hdd should do. Id go for a WD Scorpio Black or Blue. Black if noise, heat and power consuption is not an issue. Blue if you need a moderate speed, heat and power drive. Prolly have to downgrade the size of the HDD if you go Black....but you should be able to find one or the other that fits your budget! IIRC the 250GB Blacks are right at the edge of your budget. IF you can push it to $80 or so you prolly could get a 320 Black.
